hey guys,
iv wanted to buy a gtr for some time now but not still to sure on the gtr or tt supra?
i just wanna keep it all standard and use it for driving to work and back.
i have a r33 gts-t which i love but now i want an upgrade, r32 or r33 is what im picking from in the skyline range but i want a car thats quick, nice and reliable.
if anyone is selling there gtr plz pm me.
thanks alex
https://www.sau.com.au/forums/topic/253686-buying-a-gtr/
Supra TT's are pretty nice if they are nice and clean... but most of them have horrible kits, yellow headlights, really bad rims.... I looked on carsales the other day just out of interest and they only ones i likes were VERY expensive... but they were very late model and low k's so I guess thats fair enough. But one of them left stock will be very reliable, the 2JZ is one of the most over engineered engines ever built.
However, if you are leaving stock the GTR would be very good also and stock for stock would be more fun to drive i think you will find. I would just keep your options open. Just focus on a clean example weather it be GTR or Supra...
https://www.sau.com.au/forums/topic/253686-buying-a-gtr/#findComment-4384415
Having just picked up a 33 gtr myself, i would definately say go for it, awesome cars to drive especially in near standard form. If its daily driving your after i wouldn't change the stock suspension as its pretty firm but not rediculous
https://www.sau.com.au/forums/topic/253686-buying-a-gtr/#findComment-4385022
mxfly makes sense...
You might consider the 2JZ for its great shape, driver ergonomics, bullet-proof pistons/conrods
The R33 GT-R still has a proper RB26DETT racing engine, AWD, 4WS, equally great shape, reasonably good brembos, very good desirability and presence. And it's better bang for your bucks now and 3 years' time.
https://www.sau.com.au/forums/topic/253686-buying-a-gtr/#findComment-4385052
Really comes down to AWD to RWD....
Test drive both, which one you prefer, go with that. I wouldnt bother with a R32 GTR, from what i have heard, will be hard to find one that isnt going to cause you any problems.
Supra's are sexy though, got to give them that.
https://www.sau.com.au/forums/topic/253686-buying-a-gtr/#findComment-4385128
Most supra's are modified in bad taste which is very unfortunate i must say. but from going from an r33 gtst to a 33 gtr, with the right wheels they are pure porn as far as looks go, i am not a huge fan of the driver focused dash (wrap around dash) just something about it makes me dry reach :(
https://www.sau.com.au/forums/topic/253686-buying-a-gtr/#findComment-4385183
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
