Boost Issues On A S14
Fabs_32
 Share
Hey all, I know it's not for a skyline but same-diff.
Surely this could happen on a skyline, anyway.....
My mate has an s14, sr20 blacktop and was sitting at a set of lights yesterday then boosted it a little bit (he doesn't drive it very hard) and then when he pulled up at the next set of lights it just about stalled on him twice and was idoling irregular (up and down). Now it doesn't boost and when changing gears at about 2700rpm it backfires.
But then every now and then it idles ok.
What the?????
check plugs, coils, actuator lines, and inlet/return pipes for the bov.
edit, may aswell go ahead and check all the pipe joins after the turbo, just get a spray bottle full of water and go along the piping.
Edited by scandyflick
he's missing 2 cylinders for a start.
and the engine number doesnt start with RB..
yup. thats definitely it. tell him to ditch the alloy sr in favour of an iron block rb and all his problems will be gone.
/deadpan.
/deadpan.
bah, i was joking. see ref. below
<h2 class="me">joke</h2>  var interfaceflash = new LEXICOFlashObject ( "http://cache.lexico.com/d/g/speaker.swf", "speaker", "60", "18", "speaker.gif  /thinsp.pngdʒoʊk/ Show Spelled Pronunciation dictionary_questionbutton_default.gif [thinsp.pngjohk] Show IPA Pronunciation dictionary_questionbutton_default.gif
noun, verb, joked, jok⋅ing. –noun 1. something said or done to provoke laughter or cause amusement, as a witticism, a short and amusing anecdote, or a prankish act: He tells very funny jokes. She played a joke on him. 2. something that is amusing or ridiculous, esp. because of being ludicrously inadequate or a sham; a thing, situation, or person laughed at rather than taken seriously; farce: Their pretense of generosity is a joke. An officer with no ability to command is a joke. 3. a matter that need not be taken very seriously; trifling matter: The loss was no joke. 4. something that does not present the expected challenge; something very easy: The test was a joke for the whole class. 5. practical joke. –verb (used without object) 6. to speak or act in a playful or merry way: He was always joking with us. 7. to say something in fun or teasing rather than in earnest; be facetious: He didn't really mean it, he was only joking. –verb (used with object) 8. to subject to jokes; make fun of; tease. 9. to obtain by joking: The comedian joked coins from the audience.
 Share
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
