hay i just left home to day to get a oil filter so i could change my oil and 2min's in to driving the car just started to run like shit missing cylinders all over the place and there was a lot of traffic so i just kept on going got the part and headed home and i tried keeping the revs low and that didn't work so i kept the revs high but not stupid between 3g and 4g and the problem went away. but i think that the ecu could be dumping fuel in to the motor and i think that makes sense because why else would it run fine in high revs. also my fuel economy was shit in low and high rpm
so i think i know what the problem is and now how do i fix it. need help asap because im going down to be racing my car next week
my car is a nissan skyline r33 gtst s2 auto
i was shitting my self there was a cop like 2 cars back almost all the was home and im seating on 1st and 2nd omg very lucky
i just cleaned my AFM with some AFM cleaner it cost like $25 biggest rip off
the car still runs like shit
i have to go to work now will be back working on the car in 5hr
i have checked all of my cooler piping taken it all apart and put it back 2gether and it still runs bad
i now think that the amf is sending the wrong signal or the ecu is sending the wrong signal
does any body know how to check that amf 2 see if it is working without trying somebody else amf because i dont know any body with a skyline
also how to reset the ecu and could this fix the problem ??
and any other ideas for trouble shooting would be much appreciated
im 90% that it is the o2 sensor that is shitting it self so i think i will replace that
because it runs the same when it is plugged in and when it is un plugged
also if u see a skyline in WA that sounds like it is about to die it is me
and the cops in WA ant 2 bad because i haven been puled over even with all of the engine problems
if you keep guessing what the issue is like this then we might as well lock this topic and forget it.
Why ask for help when your not prepared to do what we say ?
Try another AFM. then move on from there!!!!
cocky's! Why does everyone think that the O2 sensor is the be all and end all of problems with the way an engine runs? If you have a dud plug, for example, the O2 sensor, plugged in or not, isn't going to make a scrap of difference to how the engine runs.
i did replace the o2 sensor and the car still ran the same
i have no idea why my car ran the same with the o2 sensor in and when it was out with (the old one)
and then i went back 2 the spark-plugs i pulled them all out again and the one 3ed from the front was pissing out some milky crap and so i checked the oil and the coolant to see if it was a head gasket all clear and no other spark-plugs had this problem so i swapped the shit spark plug out for a old one that i know works until i have a chance to go out and get a new set because i have had it with these platinum ones im going to copper plugs.
well any why the car runs real good with the shit spark plug out maybe even better probs because of the o2
o and by the way "Guilt-Toy" i dont know any body with a amf so how do i test it what go and buy one. not every body has $$$ to throw around
and "blind_elk" u were 100% on the money but the car does run good with a new o2 no stuttering when i am idling so not a complete wast of time
thx for the help everybody i will post pix of the dud plug some time 2day
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
