Did you bleed the master cylinder before bleeding the calipers? That is usually the first cause of "can't get the air out".
The ABS has a bleed nipple on top, from memory.
yer bled master cylinder, hmm couldnt find a bleed nipple.
//edit
this is how the book says to do it. It mentions nothing about the Master and I cannot recall having bled my master when I did it last, and the system works fine.
Disconnect Negative Terminal
Rear Left
Rear Right
Front Left
Front Right
Abs Front
Abs Rear
See bellow snippet from book.
Edited by IanB
