Im looking at the next upgrade on the engine...
I have a stock gts25t with:
pod
10psi
racing clutch
3" cat back
im looking at the next upgrade...
things in my mind are:
turbo back exhaust
safc or new comp
fmic
My question to you guys are should I get a safc or a new comp?
i got quoted $1795 with $200 for tuning for a microtech, im still learning about my car so any advice would be welcome... thanks guys..
PS. im sure there was many posts like this but im new... :P
https://www.sau.com.au/forums/topic/25376-bang-for-buck-upgrades/
  • Replies 94
fane - suss the forced induction performance section in the general board. this has some really good info...
general suggestions are to set a power target - as this will dictate what mods you do. a full ECU upgrade is better in the long run if you want big upgrades and big power, but that's not for everyone.
Putting a WA spin on it - a lot of people in the forced induction section write off the WOLF as an ecu, because there seems to be a shortage of capable wolf tuners in some parts of east AUS. However, there are a number of guys in WA who have had really good results with WOLFs...probably largely due to the fact that there is a guy in WA who is experienced at tuning them..
That's not an endorsement persae, just information to enable you to make an informed decision. there's a bulkload of info on here about the benefits and disadvantages of each ECU, so go looking and ye shall find(e).
The Wolf can loose the AFM also and has full PC tuning and a life time Australian warranty plus many extra inputs and outputs and air temp comp noto mention if customs get you ( ask Micko)
and the ECU can be upgraded in a few days so it stays current.
SAU members get discounts also.
The wolf has more features and is easier to tune though
can you give any more information here paul? cos alot of people i know who arent on the forum are having to make the wolf vs power fc decision, and its nice to know the facts on both ECUs before makin a $2,000 decision!
cheers
Adam, Sure there are alot of differences between the two, many of which have already been outlined.
MAP senor inbuilt
laptop software
more map sites than the PowerFC
airtemp compensation
inbuilt boost controller
able to control large injectors, unlike PowerFC
rotational idle, anti-lag
programable output's
extra inputs
able to switch between maps on the fly
Hope that outlines some of the reasons it's better.
fane,
If you've got flat spots in your rev range go the AFC :P I personally would go for a Hybrid Front Mount before an AFC next time.
I've got a stock dump pipe, and a 2.5" (restrictive, but "jap spec") cat and ran a pretty good time without an AFC :(
ie. My next mod will be a Front Mount :)
Paul, I'm running 700cc injectors with a PFC and I've heard of cars that run 1000cc injectors with it. Not sure what you consider large injectors but they are plenty big enough for anybody out there :P
They both have their pros and cons. Tuning for the PFC is now a lot easier and better with the Datalogit as Steve has said, and stuff like antilag isn't for street use anyway. Air temp correction is available using this too I believe. From everyone I've spoken to for street cars AFM's are better for driveability, MAP's are better for racing..
How many map sites do the wolf use?? PFC uses 20 x 20 AFAIK..
As others have said it's all about personal preference and depending on what your tuner likes may sway your decision...
You can get brand new PFC's for around the $1,400 mark now..
my 2c.
Brett
Brett, Ask N4SPD about running large injectors with the PowerFC:uh-huh:
Although the Datalogit does increase the functionality of the hand-controller it is still a more tedious process.
Wolf can run virtually any AFM aswell.
PowerFC's are good for GTR's but other than that there loosing the battle unless they decide to update there ECU.
I think if you polled the number of PFC users compared to Wolf users the stats would tell you otherwise.. :P
For mild to mid modded cars either one is more than capable, but once you start getting serious most people don't use either of these.
How good is the standard maps in the wolf? Is it as plug and play as the PFC???
Brett
And datalogit is only available for some PFC's. And not every tuner has access to datalogit, Wolf software is downloadable off the net.
Don't get me wrong, I think PFC's are great. But when you consider local warranty, price etc etc etc, Wolf comes out very very far in front.
