Frankly, don't see the point if it's a "daily". The car comes with oil pressure, water temp and boost gauges - why do you need to duplicate them. And the oil temp isn't likely to get out of control.
But if you must ...
Standard water temp guage is useless as. Even when I was hitting just on 100degC it hadn't moved from the middle.
I'd recommend an oil pressure gauge, and probably an oil temp gauge. The oil pressure for being so much more reliable, and the oil temp for actually knowing when your engine is properly up to temp.
I'm running aftermarket exhaust temp, oil temp, and boost gauge. All things not available in my car from factory. Oil pressure will be the next fitted.
Wouldn't fuel pressure be more important if i'm running an OEM Fuel pump( the fuel pump is know to die if reving too high no?) over an Oil pressure??
Anyways, people told me to get an oil pressure but I don't really get why? can you explain me the danger of having a too high oil pressure?
Thanks
P.S: I'm getting these gauges because I might start lapping this summer, if not It will be in 2 years but anyways I prefer the look of STRI gauges than the triple OEM gauge.
Oil Pessure is probley one of the most important things to watch if you wanna start lapping the track.
To make sure you are getting enough oil pumping as your engine and turbos rely heavily on it while thrashing it down the track.
Oil Pressure will only go up when you start up the car and revving it down the track.
From then on it varies, depending on the track, how fast you drive and how heavy you accelerator foot is.
It only goes down when the car is on idle.
(In my opinion) As for the gauges I recommend for track would be,
Oil Pressure gauge (As said above)
Oil Temp gauge (To check how hot your oil is getting, if its gets very hot, you best install an oil cooler to keep it at stable / lower temp so you engine and turbos perform smoother)
Water Temp gauge (To monitor and make sure the engine does not get too hot and over heat)
Boost gauge (To make sure you car is boosting at the level you want it to)
My water / oil temp usually sit at 70, sometimes upto 80 degrees, but slowly, unless you have a cooling problem (or when you get out of traffic and get some airflow the oil cooler may drop the temps).
Oil pressure changes with acceleration, so that's going to move quite a bit...
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
