Cyric;
I just fitted a GTR rear strut brace to my GTST( I hope you mean the one in the boot) And as you said I just tightened the begeebers out of it. The only problem that I saw with this was that the middle section of the brace looked crooked to the eye so I put a straight edge on the sucker and sure enough it was ! One of the rods was at a slight angle after I tightened it up, bastard ! The only way to get around this was to redrill the brackets about 8mm further out to reduce the thread length at the center adjusting nut. Now the bugger is straight and has the right amount of tension without being skewif. Just watch out that you drill thr hole exactaly in the right place(lots of carful measuring).
Hope this is of some help Dude.
yep thats great thanx dude :P its already been fitted in my car so the holes are already good to go, i just need to take the bar out so i can work on the battery and put a couple of shelves in under the hicas unit.... i was just a bit unsure as to wether or not it had to be 'magically' tightened when i put it back it, but ill just do as you did and tightn the begeebers out of it!!!
The original R33 rear strut brace should fit up to bolts already in place - all the R33 have them, so no drilling should be necessary.
As for tensioning, I dont know if this is right or not, but as my alignment was done without the bar in place, once it was fitted I just set it tight, but didnt over tighten it. The bar is supposed to stop flex, so theoretically if you overtighten it, you may cause flex in the opposite direction. It is a brace after all, not a tensioner:)
My 0.02
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
