4 sides to the relay
- 1 side will be power in (from battery)
- opposite that will be power out (to pump)
- 1 side will be relay ground
- 1 side will be the trigger (from ecu)
turn the relay upside down and you'll see some numbers:
30 - Power in
87 - power out
85 - trigger
86 - ground
ok, so are you asking if u can cut the other 2 wires to/from the relay? caus if so u cant as u need all 4 wires to run the relay/pump
u probably know this but:
the trigger wire from the std loom tells the relay when to open/close the circuit. when the relay see's power from that trigger, it closes the circuit and u get power through the relay. if u dont have power in, then u wont have power out. if u also dont have the relay ground connected, the circuit will be open and u wont get power out.
No I can see the relay's wires, these are two other wires from the pump - I don't know where they go (into the unknown of the loom). The relay has been put in to bypass the the standard variable ground pump controller which is electronic rather than a relay. It died.
The thing is that since the relay was put in, the car wont turn off, I believe because there is a voltage feeding back somehow, hence I am asking if I can cut these other two wires to the pump (it already has a power and an earth) to see if this fixes the problem.
Ok turns out they are the fuel gauge sender wires. ;)
i was gonna say that, but then u said they were keeping it running so i was confused :P
Scrap the relay and just make a new ground straight from the fuel pump to the chassis. This will bypass the variable ground pump controller..
thats not really going to work, because if u have the power coming from the battery (direct wired, which u should to get the best voltage possible) the pump will be on all the time
Alot of people do it to fix fuel problems. I have done it to mine too and the fuel pump still turns off and works fine.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
