1995 Nissan Skyline r33 With Sunroof
rb25det manual
Red/Maroon/Burgundy What Ever
ODM Reads 170,000kms (Changed Cluster as original stopped working @ 122,000)
Awesome Car To Drive (Very Responsive) and Handles Great.
Exterior:
- Full Body Kit
- 17" ROH Drift-R Rims (Near New Tires All Round)
Interior:
Everything standard apart from..
- Pioneer CD Player and 6X9's
- Iosotta Steering Wheel
- Autometer Boost Gauge Mounted Under Cd Player
- Turbo Timer (Hidden)
Engine:
- Changed To Low Kms Motor 1 year B4 I Bought It 80,000kms(claimed). Ive done 6000km.
- Pod Filter
- 3" Turbo back exhaust
- Front Mount Intercooler
- Heavy Duty Clutch (Easy to drive)
- Pod Filter
- Hks 2530 Turbo High Flow
- After Market Plenium
- Power FC with Controller
- Tuned To 210Kws + 550nm Torque
Other:
- Hks Adjustable Coils Front
- Lowered Springs Rear
Extras:
- I have a Blitz EBC just no solinoid
- Oil Catch Can (Not Installed)
Oil and Filter Changed Every 3500kms
Currently out of rego but will be sold with Fresh 3 Months
Price: Am Looking Around $14000 but open to offers
Phone: 0422 242 839 After 4pm (Am a shift Worker)
This is a must sell have purchased new "Family Friendly" car and have a wedding coming up at easter.
More pics can be supplied please pm for these.
Edited by skip187
https://www.sau.com.au/forums/topic/253796-95-gts-t-sa/
  • 3 weeks later...
  • 3 weeks later...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
