  • Replies 45
ok got the price, your looking at about $185 but itll have to come from japan. we dont usually keep them in stock cuz not many people actually buys them but we do get a few sometimes and they have to order it as well.
the thing about the harness is that not many people actually pays much attention to it so when the car is misfiring and they do the usual checks like the coils, sparkplugs, igniter, you know the usual things but forgot about the wiring. the harness deteriorates overtime and become crispy and fall apart easily because of 19 years of exposure to heat. id recommend getting a harness when changing the coilpacks for a piece of mind so you dont have to take it all apart again.
Edited by R33_NICK
Popping on WOT under boost MAY be detonation.
Considering your plugs etc are ok, and your spitfire coils are ok, the next place to be looking would be fuel.
On a side, it is a bit tough to say, and some people will get upset, but I have seen splitfire coilpacks out of the box that didnt provide spark as well as factory coils - rare, but it does happen.
Anyhoo, suggest you take it into Hyperdrive, or another REPUTABLE workshop and get them to check your air fuel mixtures (and fuel pressure) on the dyno ASAP. I have seen a few smashed engines due to fuel pumps getting tired, or injectors getting clogged (when was the last time you changed your fuel filter BTW? and when did you last clean your AFM?).
Please just get it checked out to make sure it's safe before you go experimenting - especially if you don't know for sure what it is - better safe than sorry IMO
Just get yourself an R33 series 1 turbo, and a stock ecu flash tune.
Whats that like $700 or less?
I dunno how much the R32 ECU retune costs. But a stock R33 turbo is about $300?
thats what im running and it goes sweet only cuts fuel at 15psi
+11ty
A remapped 32 ecu? or a stock ecu?
You're looking about $800 to get your stock 32 ecu remapped, I have one running my RB30 w/ z32 afm and 550cc injectors, very good solution and if you *must* have readouts like with a PFC hand controller then get a carPC and datascan :ermm:
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
