R32 Tein Nr Coil Overs Set
Yes correct. Link is at: https://hypergearturbos.com/product/atr43ssiwg/ SS2 Profile, T3 .71 Turbine housing, Ball bearing upgrade, and oil line kit. Thats pretty much it.
Can you link me to the correct one on your site? .71 P98 definitely hit 300kws without being to laggy?
Parts are brand new, decided to go in another direction so these parts are now un-needed. Includes: x2 R35 AFM units x2 NZefi adapters to connect to the factory harness x2 AFM housings with 80mm piping diameter x2 k&n universal pod filters with 4” flange $500 Free delivery Aus wide
Assume the application is for internal gate. Far as internal gate concern SS-2 makes around 300rwkws on P98 fuel in either .63 or .71 turbine housing. Response are about the same between the two.
For ATR43SS-2 on Rb25det motor, The recommended rear housing is in T3 .63 size. What power do these roughly make?
