Hey guys
Just bought my first skyline nine days ago. Thought I'll share it with you all, being reading this forum for years and all the info on here really helped me in purchasing a good clean example aswell as knowing almost everything there is to know about these cars. The car itself is really clean with 68k on the clock.
Well its pretty standard apart from the usuall, front mount, pod, turbo back exhuast with hi flow cat and adjustable coil overs.
Old owner had it dyno'd with 180 atw (didn't see papers though) with standard boost.
Heres a pic
https://www.sau.com.au/forums/topic/253858-just-bought-an-r34-gtt/
Hey guys
Heres a pic
very puuurty there bro! :D
180rwkw?......mmmm....Best YOU put her on the dyno hey? :P
Well done..and enjoy. :D
yeah 180 sounds a bit too hefty.
especially with no boost control....
im guessing around 150kw or 160kw.....
but like i said, u never know........take it to the Dyno....ring around for a price.....
Our cars are going to look very similar.
My R34 GTT runs the same sonic silver, with the same front bar option lip. You have the aero side skirts which im hoping to chase up for mine. Def invest in the clear indicators, changed the look of my car like you wouldnt believe.
I took a quick snap during the install of mine to show the difference. Ignore the crappy camera phone quality.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. ๐Ÿ˜ญ
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.ย  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.ย  If you hold the wand any more than 45 cms away from pretty muchย anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.ย  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.ย  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
ร—
ร—
