both those coolers are built for alot higher hp than that, i doubt you would see any difference between them.
are you buying a full kit or getting custom piping made up? i'd use whichever one fits easiest/has inlet/outlet in the best spot
Edited by VB-
They just sell the core, I have to buy a piping kit. Looking at the hks kit(2in 2out)
Someone told me that the stock piping easy to broken if boost over 1.2bar
lol you've been told rubbish mate. Plenty of people running 20+ psi stock piping.
in all honesty, you don't need to change the core. stock is more than adequate.
save your money
save your money
the stock core has been demaged, that’s why have to change。。
Gt2860-5R BOOST 1.3BAR(18.2psi) will make the stock piping come loose or crack, is that ture?
Best local intercoolers for my 2c
In fact the guys there make things to match the application. Not 'bolt on boy' style. Their products are second to none.
www.are.com.au
I had one made for my old gtr, similar size to stock. However it out performed it both in power and response.
Edited by rev210
the stock core has been demaged, that's why have to change。。
Have a look at your hoses, if they look old they can crack or come loose, if they look new they should be OK.
I replaced mine with full HKS SPL kit mainly for looks though, my hoses were fine
Who told you they will crack or come loose at 1.3 Bar?
it will not come loose if the clamps are done up tight enough
Is that 2 in and 2 out pipings in the HKS SPL kit?
As i know the NISMO piping kit are exectly the same as stock piping.
How is the fittment of HKS piping kit?
They told me it's easy to happen not must be
I agree, don't worry about replacing your pipe work. I run 1.3 bar (not all the time though) and over the last 3 years I have blowen a pipe off probably 3 times. Just put a screw driver in your car to put it back on. If it is a problem it is easy to replace later anyway. As for intercoolers, mine is 600 x 300 x 90 I can't say that I have realy noticed much lag from going bigger. I can't say I really saw any real gains from it either, but I did it for looks. I would go with what VB said, get the one that fits the easiest.
Blowing a pipe of is not really a problem because your car will run rich if you do, which means your not going to damage anything. Save your money it's probably not going to be a problem anyway.
can i just ask how big is the stock piping 2 1/2"???
I have an ARC M073 twin inlet. Used it with 2560R-5's. Upgraded from trust and the differance was staggering.
Have tested ARC/HKS/Trust/Apexi. (flow,cooling and pressure drop)
-ARC were the best hands down in every possible way, even give more flow to the radiator.
-Trust were good in the 150mm wide version (no pressue drop, reasonable cooling)
-Apexi Cool well due to having a longer 710mm core, but had some pressure drop(3psi)
-and HKS recorded pressure drop and suffered from heat soak after a few runs.
Still all better than chinese bar and plate.
For the power you are after I would use the ARC. Which supports up to 400rwkw and will give more throttle response/midrange improvement over the trust.
For over 400rwkw....up to 500rwkw the ARC M105+M109
Over 500rwkw
Trust 150mm single or twin inlet
The bell mouthed inlet on the ARC cores make prettty much all other coolers redundant
ARC technology explained
Goto products, Commentary ◎ cooler interface | 1 2 3 4 5 6 7. and flick through the 7 pages
Edited by BoostdR
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
