Just wondering if anyone has photos of their skyline with 19s on it or 18s, preferably r33. Just a forum link would be sweet. Trying to toss up between converting to 5 stud to get a set of 19s or just stay with 4 stud and get a set of 18s... Notice much difference ya reckon (cosmetically)?
Any opinions welcome.
https://www.sau.com.au/forums/topic/253911-19-on-non-turbo/
hi mate here are 18s on a turbo 33 i want to get 19s cause i think 18s look small now
https://www.sau.com.au/forums/topic/253911-19-on-non-turbo/#findComment-4386790
Hey man, cheers for the reply. First of all nice ride, second i think the 18s look okay...do you know how much i could pick up a 5 stud conversion for? i heard $500 odd, is that correct? does that include gts-t brakes or just the hubs for the conversion? Do you know? Cheers.
https://www.sau.com.au/forums/topic/253911-19-on-non-turbo/#findComment-4387038
Hey, You can buy 4stud 19's.. The n/a skyline im looking to get has some, and they have a center cap to hide the 4 stud. Have a look for some nice 4stud sets, im sure you will find some, and if not, you can always do the conversion to 5stud. anyway just letting you know 4stud 19's are out there so no need to update unless ur after a particular style or inproved peformance :D
Nick.
https://www.sau.com.au/forums/topic/253911-19-on-non-turbo/#findComment-4390649
N/a Skyline Thread, may see a set of 4stud 19's. : http://www.skylinesaustralia.com/forums/Wh...re-t215749.html
All R33’s Thread, good 80 pages of fun :D plenty of r33's with 19's.... even 20's :D : http://www.skylinesaustralia.com/forums/Po...33-t130489.html
Hope this helps
Nick.
Edited by Nick.
https://www.sau.com.au/forums/topic/253911-19-on-non-turbo/#findComment-4390653
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
