r33 series 1 bonnet in factory blue - $100
r33 series 1 stock steering wheel - $30
r33 series 1 stock cd player and tape player - $50 for both or $25 each
JJR stainless steel muffler - $70 (4 inch pipe into big angled cannon muffler - bolts straight on to a 3 inch system)
Apexi stainless steel muffler - $100 (oval style muffler, was fitted on my stock exhaust, so its an ideal upgrade for someone who wants to keep their stock exhaust)
all items in good condition. negotiable on prices.
jjr muffler, cd player, tape player available pick up in melbourne
all others located at my parents house in albury which are also available for pick up
will get pics up of the jjr muffler and audio stuff in the next few days, will try and get some photos of the other stuff soon
Michael - 0408169306
https://www.sau.com.au/forums/topic/253946-r33-parts/
  • 3 months later...
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
