I had a problem that i tried to fix by replacing these parts, they were not the problem, all parts are factory S1 R33 gtst.
cas $150
igniter $150
coil packs $100.
Located in frankston, willing to post but pick up preferred.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/253953-s1-r33-gtst-cas-igniter-coil-packs/
  • 3 months later...
