Hi all,
I am in the process of building a high comp n/a rb30/25 using RB25DE pistons. . I am aiming for a compression ratio of around 11-11.5:1
I was just wondering if anybody would be able to tell me the stock comp ratio (with the 25DE pistons in the 30 block with a non shaved head on a stock RB25 head gasket). .
And also how much the head has to be shaved/how much the combustion chambers cc at to achieve the 11.5:1 comp ratio (once again on the stock RB25DE pistons and head gasket)
Thanks a lot,
Josh
https://www.sau.com.au/forums/topic/253956-rb3025-comp-ratio/
Hi all,
Thanks a lot,
Josh
About 10.5:1 with the stock gasket. what your asking isn't a good idea, shaving the head can ruin squash, which combined with the fact that rb25det pistons sit recessed the the rb30 block means you will get hot spots, which will make the engine aweful at that high compression ratio (will overheat, need retarded ignition timing and extra fuel). You need to deck the block all the way which will bring the compression ratio to about 12:1, which is manageable with 98+ ron pump fuel and good management/tune. You might be able to get a reputable machinist to open up the chamber to reduce compression (whilst p&p'ing) but probably not the way to go. An alternative is using rb25det pistons, decking the block, shaving the head and running a thinner head gasket, which might get you up around where your asking (in the 11's) but i couldn't know for sure as no one has done it. A benefit of this is you could then purchase oversize forgies, increase capacity by ~ 50cc (for max oversize) and have lighter and stronger pistons (lightweight helps revs slightly with stock unbalanced motor and rods, combines with forged rods and a balance and it should be quite a weapon.)
not sure if im babbling, but the point is, the compression you will get from the 25det pistons is the most you will be able to get with them recessed the way they are. I'm assuming you want the 25de pistons for a cheaper build, so I'd recommend leaving the head as is, depends on what power your after - good flow in and out plus cams will see you 150. Though it would be smart to do the deck shaving while the block is out and bare, since its not overly costly compared to what it would cost in the future when you want more power of hit problems. I would prefer to do that and then decomp it with a thick copper gasket, than go with the recessed pistons with any higher than stock compression, as the hangover will be more costly.
Edited by SKiT_R31
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
