Hi all,
My car has a problem that has developed over the past few weeks and I cannot figure out what is going on.
The problem is the car stalls after you have pushed the clutch in/gone to neutral as you come to a stop. Its occurs most if the revs are about 1500-2000rpm or more as you push the clutch in, and the needle will just fall way past the idle point, either bouncing off 0 and coming back up, or stalling the car alltogether.
http://www.skylinesaustralia.com/forums/RP...G-SAG-t408.html
I've checked in the above thread in which people seem to have the same problems, have cleaned my AAC valve, checked to make sure there are no vac leaks, disconnected the aftermarket bov and running standard. The only other thing people seem to suggest is earthing the fuel pump so it runs 100% all the time. I DID get a new walbro intank pump a few months back but the car was fine for several weeks before this problem developed.
After fiddling around with trying to earth the fuel pump as described in the above thread i've had no luck - it seems the earth has to go back to the ECU otherwise the pump will not operate at all, so I'm not sure how to get around this problem.
Does anyone have any ideas what might be going on, or how to rig the pump so it operates all the time (without any major rewiring)?
Thanks for your help.
So stock bov is back on and installed properly?
Fuel pump is easy, just take the boot trim out are follow the loom leading to the fuel pump. Find the black wire and bolt it directly into a hole in the chassis. Try pick one that already has something else grounded on it.
Yep, stock BOV was still on car, crazy jap that had it before me felt two bovs were better than one.
And i did the fuel pump trick, but earthing the black wire just killed the fuel guage - i think the earth for the pump was white with as green stripe? But earthing that meant the fuel pump would not run at all...
Shit. so your fuel guage is ok now?
Ill go check the colour of mine...lol
Yeah its definately black. I followed the loom coming from the fuel pump up the side of the boot and tapped into the ground from there.
Edited by Bennett
Hi all,
I've been having the same issue too with mine. I find it happens most if you accelerate fairly quick and then have to come to a stop.
Do you also find your idle sometimes is all over the place? One minute it will be at, say, 1k, then it will go up to 2k all by itself.
hmm no, the idle is generally ok, sometimes hunts between 600-1000rpm, but not too bad. Have you tried cleaning out the AAC valve/adjusting the idle. That might help with that problem a bit, but it didn't help for me.
I had a similar prob a little while back and it ended up being the battery was low and because I dont drive it much these days the thing wasn't getting charged long enough. After leaving the battery on charge for a few days it solved all my idle issue.
Regardless its worth a go , the batteries in the r32's are quite small.
mark_mcq i have the same problem with my rb20'd r31 , still havn't found out what it is but its not my daily driver so not to worried, to the best of my thinking its problably my jammed blow-off making it flutter because my mates 180 does something similar with his blocked blow-off.
maybe rb20's are more prone to this because their slightly lower compression, or my ecu not being happy with VLT FLutter noises??? :D
try running just 1 blow-off ??
Check to make sure there isn't something stuck in the factory BOV return line. Mine had a coke bottle cap in it to block it off when I bought it!! I have seen that many times here on Okinawa now.
Thanks for the replies all. Unfortunately all I've succeeded in is finding out alot of people have this problem, with no guaranteed solution...
As for some of the suggestions -
-Battery - less than 6 months old, so I can't see it being that.
-Charcoal Cannister - That all looks good, I can't see any probs with leaks or damaged/perished hoses
-Factory BOV return pipe - Thats all good, had that off a while ago and it was clear
This problem really has stumped me - especially due to the fact it gradually got worse without me changing anything. I've checked the air filter etc, also running some injector cleaner through it atm. Have cleaned the plugs for the TPS and CAS, so I'll see if that makes any difference.
I still would like to try and get the fuel pump running so it is earther 100% all the time as bennett has mentioned, but I'm still not sure how i'll go about doing that...
I'm still having this problem... does anyone else have any more suggestions?
I've now checked the CAS and TPS plugs, and have also checked for error codes on the ECU and reset it - still no change.
As the car goes to stall the revs bounce of 0, come up a bit, fall back down to 0, come up a bit more, then seem to recover and get back to idle speed ~700rpm. Dunno if that info helps the diagnosis at all.
Hi, Have you tried cleaning your Air Flow Meter or checking for intermittent solder contacts inside it were the connectors go in.
See if you can monitor or log using consult or datascan the maf readings and check whats going on that way.
  • 4 months later...
Hey guys,
I am having similar problems,
r32 gts4 with rb25
- had two bovs - atmo and plumb
currently running stock plump back with flutter when engine is warm... so i assume it has failed (getting replaced)
- checked fuel pump > fine
- new battery and spitfire coils
I think its my aac which is from a rb25 stagea and doesn't really talk to my remapped ecu too well but i have to check the impedence and voltage signals when un i has finished for the semester
maybe check aac valve and its function... and check your AFM
hope this helps... let us know if u solve it too
check your intake and exhaust manifolds and make sure they are tight
had similar problems with my 32 and it was just a combo of a lot of things
also the cold start valves (on the inlet mani under the throttle body) like playing up too
trace back the val line and block it, then disconnect the plug going to it
also check your tps too, should be .5 ish volts with the t/b closed
Hi all,
hey guys, i also have an r32 gtst tht was doing the same thing until i changed my slave cyclinder out.. tht fixed the problem.. ( but.. it may only be the salve cyclinder if ur having problems  getting into gear )..
My R33 had that problem when i upped the boost. They blocked off one side of the BOV and plumbed it back into the standard plumbing (where the standard bov vented into) mechanic = me. And that fixed the problem. Now i have a top mounted turbo and they (autotech in toowoomba) have changed the exhaust manifold so i cannot see where it would vent back into standard as before. They have set it up so the bov discharges into the inlet pipe before the turbo. Now it stalls all the time. They told me that i would need a computer upgrade to fix the problem. But it seems to me that if i could plumb it back standard the problem would go away.
Would getting say a haltech x11v2 and installing that would that definetly get rid of the stall?
P.s. Not much help for the original guy who posted it sorry.
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
