Hi guys,
First off my car is idling at 1100rpm and i cant seem to lower it.
I've check the idle controller, the screw is all the way in I've adjusted the 6 the butterfly plates. Cant do it with the computer. and there's no air leaks.
What else can i do???
Cheers Tom
https://www.sau.com.au/forums/topic/253975-r33-gtr-idle-too-high/
yeah i just adjusted them. Nah didn't clean them read another thread saying don't clean the plates cause it heaps seal???
Air regulator????
Air regulator...are you sure about the throttles? Did you pull them out and clean them, or just adjust?
That could be your problem. You need to disconnect the electrical plug before adjusting the screw to get the idle correct.
(You may need to "unadjust" the butterflies too)
Yeah that's for a RB25. what do you do for a RB26???.
might have another play with it. see how i go.
Pretty much the same thing (but i havent done it myself yet so not 100% sure). The AAC is just under the plenum, held on by 4 small bolts and not too hard to get to IIRC. Here's a plenum off pic showing where it mounts - its the vertical face just to the left of the braided hoses - sorry dont have a pic of the AAC itself.
Yeah it's the same. With the engine running take off the brown plug off the back of the aac valve then screw the adjuster in to lower the idle, then plug it back in, it should then be reset. The other thing is that the idle solenoid does cark it with age.
hi guys,
i pulled off the idle solenoid and cleaned it and reset it and still didnt lower the idle. if i take the brown plug off the solenoid i can control the idle then????
You need to have the idle control unplugged from the ECU, otherwise the ECU just keeps making corrections to the AAC valve position. That defeats the whole purpose of the exercise.
Have you also "unadjusted" the butterflies?
how do you unplugged it from the ECU???
yeh i adjusted them to get the idle down, but it only went higher. so i put it back,
Bad choice of words - should have said 'disconnected'.
Simply disconnect the electrical plug from the AAC valve, that will "unplug" it from the ECU.
Put it all back to "factory" first, then do the necessary adjustments.
Hey tom !
Theres two things you may need to do,they are both quite difficult unless your competent with spanners and common sense.(no disrespect !)
first,if your idle screw is all the way in,it sounds like the spring in the valve may need a bit more tension.Directly underneath the idle valve screw you will see a circular blob of glue,behind that is another screw that tensions the idle valve,you`ll have to chip all that away,then you`ll find either a plastic or brass screw that will screw in to tension the idle valve,plastics ones are a pain so maybe you might want to go for option 2...which is...
Where your 3 throttle linkages meet the throttle cable(bolted on the plenum)remove the three(8mm headed nuts)take the adjustable linkage off the throttle control and pull on them slowly and try to feel any resistance,you should feel a slight resistance as the butterfly breaks from the closed position,repeat the process for the other two(each one controls 2 cylinders).Now if you look where they connect at the bottom of the throttle bodies you`ll see a screw(throttle stop) withanother 8mm headed lock nut,the screw has a philips screwdriver slot so you can unscrew the stop and then use the locknut to secure it.If you can experiment with the first screw(which is the easiest to get to)try unscrewing it and feel the resistance improve.
  • 3 months later...
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
