ehicle 2001 MAZDA RX-7
Price $38,000
Kilometres 41,000
Body 2 door 4 seat COUPE
Colour WHITE
Interior Colour BLACK / GREY
Transmission 5 speed Manual
Drive type Rear
Engine 2 cylinder Premium Unleaded Rotary 1.3L (1308cc)
Reg Plate RX07FD
Reg Expiry JUN-2009
Road Worthy Certificate Yes
Vehicle ID 6214212
Brief Comments Series 8 FD - GENUINE MAZDASPEED Bodykit. May consider trades.
Comments
### This car is not only unique but it is perfect for the daily driver, the sunday driver, or the person who
wants to turn heads!!! This car is not a wild monster thats horrible to drive (like many that are for sale) it
is a real fun car to drive daily or for the weekend trip.
Drive this car and compare to others available and you will see why its the one you will want.
This is the type of car you can drive to the shop and buy a loaf of bread, or take for a cruise!
### I am the first owner of this car since it arrived in Australia and this car would suit a daily driver,
weekend driver or someone wanting attention.
### I will Consider a trade or swap and or cash adjustments for a GENUINE STI WRX no older then
2002 unless it is a 2 door STI, An EVO 9, R34 GTR or a TRACK model 350z black or silver. MANUAL
ONLY! I will not consider a different car other then whats listed above thanks and sorry.
### My car is a 2001 series 8 RX-7 FD. The last of it's kind basically.
### This car is in the RARE and VERY POPULAR Bathurst white.
### It's Manual.
### It has a GENUINE MAZDASPEED GT-C BODYKIT which is has been copyrited by mazda and will
never be produced by another company. This kit from mazda cost between $4500 - $6000 so it is VERY
RARE and VERY SOUGHT AFTER!!!!!!
###GENUINE SPARCO LIGHTWEIGHT WHEELS. These are the ONLY set in Australia....
### TOYO - T1R TYRES........ BRAND NEW!!!!!!!! $1200 worth in rubber. These super gripy tyres are the
best in the dry and the wet that i have ever bought and i will never get anything else ever again.
### It is a standard and UNMOLESTED 13b twin turbo. So therefore it is incrediably reliable and
durable.
### kakimoto Exhaust
### Carbon fibre gear knob imported from the states
### GENUINE 41 Thousand Km's on the clock.
### 11 months rego
### Factory NARDI Steering wheel
### The 40 thousand K service was completed on 3/10/08 and the car has been only driven 5 times
since. (23 - 1 - 09) the car's oil change was with ONLY THE BEST Mobil 1 engine oil.
And the Gearbox and diff - ELF oils.
### full RHINO ALARM SYSTEM with remote start / Turbo timer / temp
$38000
0402329701
This car is always garaged, constantly washed and looked after.
The car also looks better in person then it does in the photo's so come and have a look and you'll leave
with the car.
Adam
0402329701
check carsales . com . au and type in 6214212 to view photo's!
Edited by rx07fd
https://www.sau.com.au/forums/topic/253988-fs-my-01-series-8-rx-7-fd/
i'll upload more photo's when i have a chance.
some of the above were taken at just jap, and homebush and my mates workshop where i had the alarm installed. i have removed the blue momo steering wheel and put back on the origional nardi one. the blue steering wheel will come with the car aswell.
thanks
  • 3 weeks later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
