Hey guys,
My mate is getting frustrated with his Airbag light staying on.
Has tried "factory resets" but the light stays.
He has the stock steering wheel and has taken the car to Nissan who found the error code "CRDRH".
Consult showed that the code is located in "other".
Doesn't seem to be affecting the driving of the car, but he would love to have it gone.
Any suggestions?
https://www.sau.com.au/forums/topic/254024-airbag-light-on/
Nope.
Still there.
Any ideas?
Anyone??
..... Bueller???
Has he played around with the airbag? like has he installed the radio controller? Maybe plug in the back has come loose.
I have no idea really but I thought I would trow you a bone so you know we are trying to think of a solution.
Is this your mate with the $400 M35? If so, maybe think about the options fitted and where they may cause a problem to the airbag?
Cheers and good luck.
Andy
Edited by andy65b
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4389510
Andy
Such a memory you have there sir!
Yes it is the $400 M35.
Can't really think of any aftermarket stuff installed that would have interfered with the airbag.
Maybe the entertainment system he has in there, or the Nismo dash could have effected it when installed.
The confusing bit is that it has disappeared in the past - although very briefly before it came back.
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4389596
when i was doing trimming and the seats were removed from cars (mostly euros, but newer nissans are likely to be similar) and the car was then driven the airbag light would say on. the only way to get it turned off was to have a dealer reset the airbags via a diagnostic style tool. possibly the airbag plug under the seat has been unplugged or has come out??
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4389607
I have exactly the same problem with my car... It came imported from Japan with an aftermarket steering wheel.. everything was fine still one night air bag light starting flashing and hasn't turned of since.. nothing had been touched so I'm not sure why it came on all of a sudden..
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4390013
  • 1 month later...
Mine started flashing tonight and it won't go out :banana:
Wheel is stock, havn't had any collisions or anything.
Did anyone find a solution or a reason for the Airbag light to flash constantly? (comes on solid when you turn ignition on but once the engine is running it flashes).
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4498695
Try this Stephen... worked for my mates car (although the light just came on again).
Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash.
To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4499171
I will give that a shot, thanks dude!
I don't know as of yet what the actual error code is for my particular problem. I just tacked it on to this conversation as it referred to M35 issues with the airbag instead of starting a whole new thread.
I've been driving most of the day so I've seen enough of my car for now lol. I will give it a go tomorrow morning though and if it doesn't gel I will take it to Hornsby Nissan and get them to check it out. I want to go and meet the guys and let them know they'll have a new customer for all things nissan (i've still got to get around to getting a new rear sunroof rubber fitted, it's on the back burner for now tho!).
Once again, thanks for the assitance. Even if it doesn't help me on this occasion it's in the thread now so other's might find it if they have airbag issues.
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4500276
Further to my last email I did end up going for a quick drive afterall, and I tried the suggested method and the light has now gone out.
However, if there is an issue that needs my attention I'm sure it will come back on, that being the case I will go and get Hornsby Nissan to check it out a bit further.
Thanks again :D
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4500679
  • 4 months later...
need a tool attached to it for a proper idea. common thing is the seat tensioners. also bea in mind that the controller used in those was the same as the local 350z and 02/03 versions had issues with the controllers.
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-4738106
  • 7 months later...
Guys,
My airbag light was flashing and I found the solution on the net and it worked first go on my M35.
Turn the ignition to the "on" position. Watch the airbag light closely(it will be on solid) the split second it goes off(beggining to flash) turn the ignition off, count to 5. Turn back to "on" position and do the same another 2 times.
Next time you turn it to "on" position it will blink really slowly(diagnosing) Then switch off. Next time you turn it on it will be solid and then turn off completely.
https://www.sau.com.au/forums/topic/254024-airbag-light-on/#findComment-5141321
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
