  • 1 month later...
Finally got time to get up to see Chris and he confirmed my yellow plugs dangling under the seats have nothing to plug into. The anti-submarine rams are completely missing from both front seats.
"Well, there's your problem" :blush:
So my airbag fault is different from most. I reckon there wouldn't be too many others out there that started investigating a flashing airbag warning light and found out the components had been NICKED.
EDIT: deleted name, address (physical & email), phone number & identikit photo of culprit. For legal reasons. :(
  • 1 month later...
I know this is reviving an old thread...but.... I had the airbag light on. Did the key reset and it came back after a couple of days. Took it to the workshop (C-Red in Perth :thumbsup: ) and Mark chucked it on his scanner. No code came up and he reset it properly and it's been good ever since. Mark said there is a known glitch with the V/G/M 35 airbag system- something to do with a passenger side seatbelt switch.
  • 1 month later...
  • 1 month later...
Guys,
My airbag light was flashing and I found the solution on the net and it worked first go on my M35.
Turn the ignition to the "on" position. Watch the airbag light closely(it will be on solid) the split second it goes off(beggining to flash) turn the ignition off, count to 5. Turn back to "on" position and do the same another 2 times.
Next time you turn it to "on" position it will blink really slowly(diagnosing) Then switch off. Next time you turn it on it will be solid and then turn off completely.
hi fellas,
same thing happened to my m35 last night,just tried the above method. It worked..So far so good.Will report back a little later to see if the fix is long term .
Thanks so much for all the advice/ help we pick up on this site.
graham
  • 1 month later...
Try this Stephen... worked for my mates car (although the light just came on again).
Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash.
To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset
Thanks for this I was racking my brain trying to clear the same problem.
The golden question is - will the airbags still work!
and the more pressing question in fine print : is my insurance still valid after I bypassed a safety device. (think about it.)
Im not sure if the insurance question is more pressing than the safety one Chris :P
ok after looking into the seats, i dont think the non-electric seats have the rams in them.
i think the plug is just a switch to see if someone is sitting in the seat so the airbag computer knows to deploy any bags in the event of an accident.
i dont want to rip apart my nice RS seats, but it disappears into the bottom cushion
Do these cars have a model that comes without seat bags?
If they do legally you can bypass the seat bags according to the RTA in NSW.
Been there, done that a number of times while i was doing airbags for a living for 5 years.
Of course, the base model has no seat bags or electrics and I haven't seen a ram under mine either although there are plenty of wires. I agree with Duncan, getting the system out of fault so the bags deploy in an accident is much more important to me than how the insurance company will weasel out of their contract.
RS leather optioned seats do not have air bags either... unless the safety option was also ticked by the original purchaser.
I wish the previous owner of mine (RS with leather) wasn't so safety conscious, then I wouldn't have to go thru all this crap pinch.gif
  • 1 month later...
Hi,
Not sure if this would help - but I had the same annoying problem with my Stagea - got it reset a couple of times and then tried resetting it myself (after reading this forum) with occasional success.
Even called Chris regarding costs for new seats.
Anyhow - took it to Victoria Park Auto Care in Perth and he said something about he cut the yellow plug out from under the seat and bypassed it so it was hardwired (?), said its a common circuit problem with a number of car such as Falcons and BMWs.
It cost us $200 to repair and light had not come back on!
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
