  • 1 month later...
Finally got time to get up to see Chris and he confirmed my yellow plugs dangling under the seats have nothing to plug into. The anti-submarine rams are completely missing from both front seats.
"Well, there's your problem" :blush:
So my airbag fault is different from most. I reckon there wouldn't be too many others out there that started investigating a flashing airbag warning light and found out the components had been NICKED.
EDIT: deleted name, address (physical & email), phone number & identikit photo of culprit. For legal reasons. :(
  • 1 month later...
I know this is reviving an old thread...but.... I had the airbag light on. Did the key reset and it came back after a couple of days. Took it to the workshop (C-Red in Perth :thumbsup: ) and Mark chucked it on his scanner. No code came up and he reset it properly and it's been good ever since. Mark said there is a known glitch with the V/G/M 35 airbag system- something to do with a passenger side seatbelt switch.
  • 1 month later...
  • 1 month later...
Guys,
My airbag light was flashing and I found the solution on the net and it worked first go on my M35.
Turn the ignition to the "on" position. Watch the airbag light closely(it will be on solid) the split second it goes off(beggining to flash) turn the ignition off, count to 5. Turn back to "on" position and do the same another 2 times.
Next time you turn it to "on" position it will blink really slowly(diagnosing) Then switch off. Next time you turn it on it will be solid and then turn off completely.
hi fellas,
same thing happened to my m35 last night,just tried the above method. It worked..So far so good.Will report back a little later to see if the fix is long term .
Thanks so much for all the advice/ help we pick up on this site.
graham
  • 1 month later...
Try this Stephen... worked for my mates car (although the light just came on again).
Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash.
To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset
Thanks for this I was racking my brain trying to clear the same problem.
The golden question is - will the airbags still work!
and the more pressing question in fine print : is my insurance still valid after I bypassed a safety device. (think about it.)
Im not sure if the insurance question is more pressing than the safety one Chris :P
ok after looking into the seats, i dont think the non-electric seats have the rams in them.
i think the plug is just a switch to see if someone is sitting in the seat so the airbag computer knows to deploy any bags in the event of an accident.
i dont want to rip apart my nice RS seats, but it disappears into the bottom cushion
Do these cars have a model that comes without seat bags?
If they do legally you can bypass the seat bags according to the RTA in NSW.
Been there, done that a number of times while i was doing airbags for a living for 5 years.
Of course, the base model has no seat bags or electrics and I haven't seen a ram under mine either although there are plenty of wires. I agree with Duncan, getting the system out of fault so the bags deploy in an accident is much more important to me than how the insurance company will weasel out of their contract.
RS leather optioned seats do not have air bags either... unless the safety option was also ticked by the original purchaser.
I wish the previous owner of mine (RS with leather) wasn't so safety conscious, then I wouldn't have to go thru all this crap pinch.gif
  • 1 month later...
Hi,
Not sure if this would help - but I had the same annoying problem with my Stagea - got it reset a couple of times and then tried resetting it myself (after reading this forum) with occasional success.
Even called Chris regarding costs for new seats.
Anyhow - took it to Victoria Park Auto Care in Perth and he said something about he cut the yellow plug out from under the seat and bypassed it so it was hardwired (?), said its a common circuit problem with a number of car such as Falcons and BMWs.
It cost us $200 to repair and light had not come back on!
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
