Hi all,
Seeing as the previous group buys were so successful i am now able to supply a variety of HID KITS.
Kits are supplied by SDC Performance.
And this GB will run from 25/1/09 to 26/2/09.
These will range from your standard 35w HELLIGKEIT HID KIT to the top of the line BOSCH HID kit
So here is the run down:
HELLIGKEIT HID
3 times the light output
10 times lifespan
Greater visibility
Less power consumption
All bulb sizes available: H1, H3, H4/9003, H7, H8, H9, H10, H11, H13/9008, 9004, 9005, 9006, 9007, D2S, D2R, 880/881.
All colors available: 3000K(Golden Yellow), 4300K(Extreme White), 6000K(Diamoand White), 8000K(Iceberg Blue), 10000K(Brilliant Blue), 12000K(Violet purple)
BOSCH HID/ SIEMENS HID
10 times lifespan
Greater visibility
All colors available: 3000K(Golden Yellow), 6000K(Diamoand White), 8000K(Iceberg Blue), 10000K(Brilliant Blue), 12000K(Violet purple)
2 Digital Ballasts
2 Xenon Bulbs
10 Zip ties
2 Heavy duty heat resistant double sided self-adhesive pads
Manual
Warranty Card (Required for warranty replacement)
SPECIFICATION
l Power consumption: 35watts
l Voltage: 85V +/- 17V
l Service Life: up to 3000hrs
l Input Voltage: 9V-16V
l Working current (Steady state): 3.5 A nom
l Ignition voltage: 24kV Peak Max, 18kV Peak Min
l Lamp Frequency: 450 Hz
These Xenon bulb are precisely machine based to maintain the exact focus point and consistency The precision guarantees the beam pattern will be the same as your OEM, and of course with dramatic increase in intensity thanks to the Xenon technology. The burner are manufactured in Japan in Class 100,000 clean room to ensure the purity of the Xenon gas enclosed in the capsule and consistency of the color temperature from batch to batch. These bulb will outlast and out outperform all of the Xenon bulb out on the market with least blow outs.
Prices:
HELLIGKEIT HID-- $135 DELIVERED ($195 for H4 Bi-Xenon)
BOSCH & SIEMENS HID-- $225 DELIVERED ($295 for H4 Bi-Xenon)
( Kits take between 5-10 working days to arrive after payment )
All pics and some tech info can be found here: http://www.skylinesaustralia.com/forums/Hi...-3-t250159.html
If you want the 5000k look, you will need to order the Helligkeit 4300k as this is the closest colour temp to it.
https://www.sau.com.au/forums/topic/254030-hid-group-buy-revised/
  NYTSKY said:
For anyone interested. PHILIPS HID kits are also available:
$249 DELIVERED
are these kits available for pick up? if so, what price?
Will 5% discount still be applicable for pick up price on 2 sets?
  NYTSKY said:
Yes 5% discount is available on 2 or more kits.
Price is the same pickup or delivered.
Just confirming if youve used either the:
- Bosch kit
- Phillips kit
before?
Professional opinion: Is there a justifyable difference in choosing the Phillips kit?
Ive heard both brands are good quality.
PM me bank details.
Although not listed, Im after 4300K kits. If none, highest ill go is 5000K. D2S, 35w
- brand, pending your reply
- Bosch kit
- Phillips kit
before?
PM me bank details.
PM sent.
hey mate,
interested in a hid kit. Can you possibly tell me what globe type i need for R34 Gt-t. Had factory xenons in it but they were removed on compliance. Also can you tell me is there a diff between the philips and bosch kits? What sort of warranty is offered?
