Hi all,
Seeing as the previous group buys were so successful i am now able to supply a variety of HID KITS.
Kits are supplied by SDC Performance.
And this GB will run from 25/1/09 to 26/2/09.
These will range from your standard 35w HELLIGKEIT HID KIT to the top of the line BOSCH HID kit
So here is the run down:
HELLIGKEIT HID
3 times the light output
10 times lifespan
Greater visibility
Less power consumption
All bulb sizes available: H1, H3, H4/9003, H7, H8, H9, H10, H11, H13/9008, 9004, 9005, 9006, 9007, D2S, D2R, 880/881.
All colors available: 3000K(Golden Yellow), 4300K(Extreme White), 6000K(Diamoand White), 8000K(Iceberg Blue), 10000K(Brilliant Blue), 12000K(Violet purple)
BOSCH HID/ SIEMENS HID
10 times lifespan
Greater visibility
All colors available: 3000K(Golden Yellow), 6000K(Diamoand White), 8000K(Iceberg Blue), 10000K(Brilliant Blue), 12000K(Violet purple)
2 Digital Ballasts
2 Xenon Bulbs
10 Zip ties
2 Heavy duty heat resistant double sided self-adhesive pads
Manual
Warranty Card (Required for warranty replacement)
SPECIFICATION
l Power consumption: 35watts
l Voltage: 85V +/- 17V
l Service Life: up to 3000hrs
l Input Voltage: 9V-16V
l Working current (Steady state): 3.5 A nom
l Ignition voltage: 24kV Peak Max, 18kV Peak Min
l Lamp Frequency: 450 Hz
These Xenon bulb are precisely machine based to maintain the exact focus point and consistency The precision guarantees the beam pattern will be the same as your OEM, and of course with dramatic increase in intensity thanks to the Xenon technology. The burner are manufactured in Japan in Class 100,000 clean room to ensure the purity of the Xenon gas enclosed in the capsule and consistency of the color temperature from batch to batch. These bulb will outlast and out outperform all of the Xenon bulb out on the market with least blow outs.
Prices:
HELLIGKEIT HID-- $135 DELIVERED ($195 for H4 Bi-Xenon)
BOSCH & SIEMENS HID-- $225 DELIVERED ($295 for H4 Bi-Xenon)
( Kits take between 5-10 working days to arrive after payment )
All pics and some tech info can be found here: http://www.skylinesaustralia.com/forums/Hi...-3-t250159.html
If you want the 5000k look, you will need to order the Helligkeit 4300k as this is the closest colour temp to it.
https://www.sau.com.au/forums/topic/254030-hid-group-buy-revised/
Yes 5% discount is available on 2 or more kits.
Price is the same pickup or delivered.
Just confirming if youve used either the:
- Bosch kit
- Phillips kit
before?
Professional opinion: Is there a justifyable difference in choosing the Phillips kit?
Ive heard both brands are good quality.
PM me bank details.
Although not listed, Im after 4300K kits. If none, highest ill go is 5000K. D2S, 35w
- brand, pending your reply
- Bosch kit
- Phillips kit
before?
PM me bank details.
PM sent.
hey mate,
interested in a hid kit. Can you possibly tell me what globe type i need for R34 Gt-t. Had factory xenons in it but they were removed on compliance. Also can you tell me is there a diff between the philips and bosch kits? What sort of warranty is offered?
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
