Hi there,
Was removing my radiator today when i noticed from under the car that the clutch fan has a crack in it, on the part that sits around bearing on the motor. See pic:
As you can see, the crack is about 1 cm in size.
Obviously the smart thing to do would be to replace it, but i'm curious if anybody's had a similar issue or a fan fail on them due to cracking.
Also, if anybody's got a spare one lying around that would be great.
Thanks
https://www.sau.com.au/forums/topic/254032-crack-in-clutch-fan/
just put a bigish thermo on it with a proper shroud.
electric fans get a lot of bad rep but personally i reckon most of this is due the people running them unshrouded and not big enough fans.
for instance i've been looking at fans for my hilux. the one on it was a 16 inch flowing 1000cfm (i think) yet 2x 10inch fans wouldn't flow even close to that.
kinda the same argument such as a single 4 inch pipe will flow more than 2x 2inch pipes by a significant amount, but i get the shits arguing with people about this.
On my r33 i found a crack about the same size as yours. Went for drive that night to get something and the fan split and went into the radiator.
So instead of just having to buy a new clutch fan i also had to buy a new radiator.
Get it replaced as soon as you can as you never know when they will fail.
Where abouts did you get a new one from? I had to trim the blades on the stock one for the intercooler pipe so wouldnt mind buying an aftermarket one that fits on without needing to be trimmed.
Anybody with a Hybrid FMIC know of an aftermarket brand that doesnt require trimming of the blades?
they fatigue after a while.
almost all r31 and vl have this fault as well that i have seen.
i would just double check that the viscous fan centre is working properly, not locked up all the time as this will put extra load onto the blades.
A 16inch SPAL fan from PWR will flow 3000cfm. I don't know of any that flow higher but they are good value if you are having cooling issues and they can't be fixed by the normal maintenance procedures.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
