hey fellas, clearing out parts to make room.
1. 7M-GTE intercooler, good upgrade for RB20/25 and keep the standard cooler piping path & good for budget DE+T conversions. $30
2. R33 GTST SMIC + some random stock pipes, suit RB20/R25 - good for budget DE+T conversions & clearing defects.
good condition $15
3. OEM R34 GT/T coilpacks x 13
6x have high temp silicon around them
7x standard
all 13 for $150 or $20ea
4. R33/R34/Stage RB25DET turbo > afm rubber intake pipe in good condition, no rips or damaged bits. good for replacing old worn out ones or for budget DE+T conversions
$20
5. R33 Series 1 GTR BOV, in good nick, good upgrade for GTST (holds more boost then GTST one without leaking) and for budget DE+T conversions $50
6. 99' R34 GT(NA) stock suspension done 70,000km (fits R33 GTST as well)
Good condition - no leaks, damage or knocks, good for clearing defects, removed because i got coilovers
$150
7. VQ30DET turbo complete with actuator, good upgrade for RB20/RB25 or budget DE+T conversions (same specs a VG30DET turbo),
$170
http://www.vq30det.com/phpBB3/viewtopic.php?f=1&t=29
8. R33 GTST/ R34 GT/X (wont fit GTT or GTV) G4 adjustable coilovers, 10kg front, 8kg rear, to firm for my liking so going for something softer, this is more suited to a car that hits the track (mine is a streeter only) comes with 2 spare 7KG springs $850 will swap for something comfier
9. R33 GTS/T standard timing belt cover in good condition
$20
all items are located in sydney, north ryde during business hours & next to liverpool Krispey kreme after hours & on weekends. prices are for pick up only, please contact me for delivery but with the small things, they'll be $10 max to send interstate.
phone 0413544494, do not SMS as i won't reply
i am in need of a few parts so we can do a swap + cash adjustment where needed;
turbo timer to suit R34
3" cat
emanage blue injector harness & ignition signal adaptor
3" mildsteel front/dump suit R33/34
7x standard
$20
turbo, stock suspension, intake pipe, bov & both coolers SOLD
only whatever is listed in this post is left.
how much more power would you expect from that turbo with mild mods - exhaust, front mount, more boost on a R33 GTS S2??
hello mate,can i get the dimensions for the 7mgte cooler,and is there any additional piping needed to attach to a RB25det?thanks
i dunno if you guys can see it or not but both of those items you enquired about are SOLD
Cheers
  • 2 months later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
