Well i have spent ages trying to work out why my gear box keeps spilling fluid out through the breather in the gear box. No seals are leaking, its just coming out of the breather. It didn't happen with the previous fluid that was in there only once i put the shock proof stuff in.
Once i changed it, i poured almost the full bottle in, 3.6L roughly. Since then it just has been leaking, so i ran an rubber hose to the top of the engine bay, so most of the time this is enough to stop it. It hasn't and now i'm considering changing to another type of gear box fluid as it sh*ts me to tears.
anyone had simular problems? cause its meant to be good stuff.
Anyone got/had simular problems?
Thanks in advance
https://www.sau.com.au/forums/topic/254077-redline-shock-proof-problem/
did you fill it correctly through the filler hole and not through the shifter and guess the amount of fluid?
if it is filled correctly, i.e. correct level, running out of filler hole with the car level, then change to another fluid.
redline is over rated in my books anyway.
Nar mate it was filled via the shifter from the cabin, but i unscrewed the bolt on the side of the gear box (filler?) and the fluid level seems ok.
I have always run smurf blood in my R33 with no issues.
I would suggest that there is too much oil in the box. Park the car on a level site and remove the filler plug on the side of the box to drain out any excess oil.
Is this a GTR or GTS-T?
The shifter goes into the transfer case on a GTR, so if you filled the transfer case youve mixed ATF and synthetic, and are running your gearbox dry.
And... I think the GTS-T's are supposed to use Redline ultra-lite weight, not the light weight. Its more like an ATF oil that is used in the R34 getrags as wel.
Its just a single turbo! and i done my research and everyone said its fine, plus mechanics, redline and search engine
But thanks anyways!!!
I just realised that i'm gonna try a rachet so i can adjust the angle and on the way home pick up a water pipe for extra leverage :blush:
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
