Guys,
any idea what a good weight distrabution for an R32 GTR is i have weighed mine and have roughly a 58% front / 42% rear split and a diagonal weight difference of 18 kgs with driver and fuel.
Anyone else played around with this?
https://www.sau.com.au/forums/topic/254119-r32-gtr-weights-splits/
about to do mine in the next few weeks....I will post up too. GTR is too nose heavy but we will do what we can.
I spoke to someone about this the other day - apparently all the super cars run lead because left to right balance is more important than overall weight...interesting to consider.
Ok another go at the corner weights this weekend.
With driver and full fuel load i got the following.
front left 415kg
front right 444kg
rear left 291
rear right 309
So that is a FR to RL total of 735 kg and a FL to RR of 724kg
I cant get it any better without moving some the gear already installed into the car, so next week i start cutting the fuel cell, pumps mounting brakets and fire extingister and getting them all to the rear left corner. Once i get that corner heavier i will be able be able to better balance out the entire car
  • 4 weeks later...
Well as promised here are the results from mine.
First thing I notice is that your car is a full 100kg lighter than mine so well done. the numbers are pretty depressing but meh.
FL 433kg
FR 471kg
RL 307kg
RR 346kg
That gives me diagonal cross weights of 779.5kg vs 780.5kg. Nick has a pretty good eye for setting this up.
Ride heights to acheive that guard to bottom of wheel (with 17" wheels) is:
FL 570
FR 575
RL 565
RR 567
So basically they focus on getting the diagonal weights right because that is where the wieght shifts on your average corner turn in under brakes. He did this by managing the ride height at each corner not by moving stuff inside. And its amazing that .5cm of difference in ride height makes up for 38kg in weight difference.
Also its painful to note that the front to rear distribution is 904F to 653R = 60%F 40%R
So... FR takes 1.5x the weight of the rear right. so anyone that tells you that they need larger rear tyres on a gtr is very much on drugs. given that generally gtr owners run same size wheels all around, and that the main weight shift is under brakes, the fronts will always be the tyres working hardest (this matches with what I have seen in tyre wear and tyre pressures)
Exactly. I would have thought ride heights will have the biggest impact on the corneer weights. Remember, the chassis is meant to be rigid, so you can't really change corner weights any other way. Front to back is a different matter, so the more crap you can mount in the back, the better.
This stuff makes me cry.
Mine is still full weight ie stereo, interior etc with just a few things done to help matters eg HICAS.
Front is 905kg
Rear is 685kg.
Which gives a distribution of 57/43.
I should point out that I weigh 100kg with helmet etc.
Sorrt of explains why the things understeer so hard.
yes duncan i have removed every bloody thing possible even down to alloy bolts if its not load bearing.
I plan to get a full T45 cage in over summer here and a wide body kit i have to do something to catch the bloody viper Z06 GT2 etc
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
