hi guys, haven't been on here for while but something has come up that you guys my be able to shed light on.
during some research on non turbo models i've come across a variant of the r33 gts that has vented discs on the rear. 266mm by 18mm. to date i believe this model to be named the gts urban liner s (might have a different name in different areas) its an auto (at least the one i know of is) and has the rb20e engine.
anyone ever come across these rear discs before? and more importantly had to source replacements? after much searching replacements for vented rears at this size with integral drum brake are rarer than a Scotsman buying a round of drinks!
any and all help and suggestions would be great.
si
Edited by Hesh
https://www.sau.com.au/forums/topic/254120-odd-brake-set-up/
My R34 25GT Sedan had 265mm Rear Discs with single pot calipers...not sure if that really helps you much though :D It was a pain to get any decent discs for them as well, I ended up upgrading the whole brake set up in the end. I was only able to get 265mm in plain non-slotted items. I'm wondering if it's the same brakes that were used on the R34 Sedan.
Yeah, both front and rear ventilated, front were 280mm 2 pot caliper, the rear were 265mm 1 pot caliper.
These were the front 280mm that I had removed:
http://i73.photobucket.com/albums/i229/l33...C00765Large.jpg
And these are the rear 265mm ones:
http://i73.photobucket.com/albums/i229/l33...C00766Large.jpg
The front calipers:
http://i73.photobucket.com/albums/i229/l33...C00768Large.jpg
http://i73.photobucket.com/albums/i229/l33...C00769Large.jpg
The Rear Calipers:
http://i73.photobucket.com/albums/i229/l33...C00770Large.jpg
Not sure if visually they are the same? Wouldn't suprise me if Nissan used them on more than one model Skyline, and if it's a RB20E than it's hardly going to need the bigger brakes in its stock form (after all these came of a RB25DE R34 Sedan).
If they are the same, then don't expect to find many aftermarket listings for the rear brakes. My local brake shop told me they could get them in plain RDA discs. Getting anything better than that seemed near impossible, and with a turbo conversion on the way I just upgraded them, and saved the hassle for future replacement parts.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
