Is Flat-sticking Bad For Your Car? (automatic)
i do it in my skyline r33 all the time... apparantly my friend said its bad for my car.. but i prety mch flat-stick everytime i go past a stop sign..
*its because my car exhaust is rly loud and the only way to make it sound less loud is to flat stick.. thats jus how i drive . lol. its hard to explain.
  • Replies 65
Posted Images
Flatstick
1. Golf
Definition: Slang term for a putter, because putter faces are considered flat relative to other golf clubs.
Reality check: Most putters are not, in fact, flat. In other words, putters, too, are lofted. You can find putters with zero degrees of loft (true "flatsticks"), but most putters have 3-4 degrees of loft to their faces.
Alternate Spellings: Flat stick
I don't know if it's just me, but automatics and loud exhausts just don't mix.
I don't know what flat sticking is either.. but if I think it's what you're doing (moving the gear selector up and down manually selecting gears excessivly), you are damaging the linkages between the gear selector and the gearbox itself. Autoboxes like that are meant to be left in D, not to be treated as if they were tiptronic gearboxes. That's just my opinion.
:D
Guest
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
