  • Replies 45
my spool is fitted very happy with it almost half the weight of the oem centre yet it looks indestructable
gearbox is a powerglide
and the doors are being made in 100% carbon fibre should be ready in may (being made locally brisbane)
how long till your car hits the track???
Edited by jas/slo32
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4515214
and the doors are being made in 100% carbon fibre should be ready in may (being made locally brisbane)....
that sounds great.....can you post up the weight with windows when you get them back? Would love to know how our lightened std route compares to full CF
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4527293
Havent got the doors yet but did take the car to the weighbridge on the weekend @ race weight full fuel oil etc
car 1130kg raceweight
car with driver 1210kg
im hoping with carbon doors/bonnet/boot to get the car just under 1100kg but 30kg is alot of weight
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4538274
  • 5 months later...
Car will be for sale shortly with new engine 0 hours use
details
engine
rb26/30
grout filled block
nitrided crank
cp pistons
argo rods
arp rb26 head studs
hks 272 cams
arp bottom end studs
acl race bearings
jun oil pump
ati 1000hp balancer
ati dry sump drive (for fuel pump)
hks manifold exh
garrett gt42r
custom plenum with 100mm t/b
1800hp belt driven fuel pump/reg
12x 1600cc injectors
electrics
motec m8oo
msd dis 4
motec coils
6x egts
5 bar map sensor
all new wiring
driveline
2spd powerglide checked over rescently
new 6000rpm converter & vasco input shaft
1pc tailshaft
diff
gtr rear end
new full spool centre
new bearings
heims joint adj toe arms
body lightweight
as per previous post
gtr front guards
lexan windows
frp bonnet
frp headlights
current tech
minitubbed
parachute
14lt fuel cell
4lt catch tank
wheels
new 15x8 billett rear
new 15x3.5 billett rear
26x4 front
28x10 rear
price $40 000 ono with car trailer pm for more details
or ring 0424348521
Jason
Edited by jas/slo32
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4848287
  • 1 year later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Car is now for sale as a roller minus engine,trans,tailshaft,ecu,cdi & rego plates.
Weighs 1179kg race weight with 90kg driver
car drives straight,current tech,6 point cage etc etc
$10k ono need to make way for chassis car
Phone Jason 0429232288
located bundaberg qld
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-6128763
    • The Neat gears use an alternative profile, no? Something different to what normal OEM stuff is. Is the noise at all traceable to that? Reason I ask is that my CW&P are effectively past their use by bate and Neat is the obvious option.
    • Just picked up my first skyline. R34 4 door with an rb25det and manual swap. I’m in the US. It has a bunch of issues but the problem I’m chasing now is the indicator, hazards, and horn do not work. I took out the indicator relay and fuses and tested separately and they seem to be working fine. When I activate the turn signal stalk or the hazard button nothing happens, no clicking, and no dash lights. Same with the horn. What should I test next? The headlights, taillights, and brake lights work fine so I think the stalk is good.
    • RD25 neo... sorry bad joke ill see myself out
    • Sorry just googled Toyota WiLL Vi and wish that I didn't, day ruined, fark etc.
    • So mines not in yet ... which should tell you something ...   I got a set of neat gears as well, took a year to get those. Then the setup was a real tricky one, with all the changes. It seems the shims for the front diffs are in short supply and had to wait two round of custom ones. This was all done by a professional diff builder , not me/diy.   So here we are about to go into 2025 and I do finally have a built front sump / diff / gears.  Just need the mojo to pull out the engine ...   Oh as an aside on the neat gears, they have some whine, mostly on decel. Taken a bit of setup again to get that down to a street car level.
