Hey guys, our track miraculously won't start now once I hit the button
Its a forged RB25
Microtech LT12S
GT35R
etc etc etc
Now when I turn the key it cranks and cranks forever but will not fire
There is no spark from the Splitfire coils, and the injectors do not tick
When the ignition is switched on, with CAS removed from engine, and I spin the end of the CAS - both the injectors and coilpacks tick, however when I put the CAS back in the engine - theres nothing
I am bamboozled - have replaced CAS, and Ignitor to no avail.
I am wondering if maybe tehre is a voltage drop somewhere in the electrics of the car???
Any idea or things to check would be great!
Check the wiring for breaks going into the CAS. Maybe by removing the unit you are bridging a broken gap in the wire.
Long shot but it's the first thing I would check.
Also make sure the drive on the camshaft is still there.
Pretty much there are lights on the side of the ecu, pretty sure the red one flashes when there is a problem. If it flashes, check your hand controllers error log screens (screen 33 off of memory) and it will show what error options there are.
ErrorChk1 is for air temp, crank angle, home and ref
ErorrChk2 is for MAP, RPM, TPS and DC volts
See what it says from them and start from there.
check your fuses
Mine was a stupid blown fuse (yes I did check them first)
same thing i could take the cas out turn it and there was ticking only problem was i couldnt get a spark (occasional weak spark)
but when we looked at fuses again there was a blown one
changed that and away she went
I have a handset controller but the screen died months ago - it occassionally shows some info - i have used another controller on the ECU and it works fine so I guess my controller is only good as a paperweight now
check your fuses
I checked all the fuses like 10 times - theres only 5 in the cabin for the whole car :D
Highly unlikely, but I had an issue with mine recently where the green wire for the fuel pump relay wasn't working, I ended up wiring the relay straight to earth, till I can either get it fixed or find a better solution.
Auto Sparky who re-wired teh whole car is coming out tonight to look at it - jus seems weird that teh CAS when spun by hand makes the coilpacks emit spark and injectors tick - which would make me think the ignitor is fine - however once u try and crank the car, the CAS does nothing. I have watched cranked engine with no CAS fitted and the end of the cam definitely spins :D
Edited by The WOR57
As the WOR57 stated is the drive inside the cam engaging into the cas locater?
Check for bad electrical contacts if you sad that when you remove the cas it triggers the inj's then it sound like bad conecction
the keyway in the end of the cam spins, which in turn I would assume spins the end of the CAS.
    • Welcome. Dont let anyone dissuade you from your dreams. If you want a gtr, keep sabing and you will eventually get one. I feel like if I had have bought stocks, those companies would have gone bust and I would have lost my money.  There's a gamble in everything we buy. I've had good times and bad. But... I've also met my absolute best friend through this network and can't imagine life without them(more like a brother). Keep in mind, some specific mods will change as technology gets better. If you feel like general chat, there's always the wasteland.....
    • Those are some very cutesy barriers! Is that common?
    • Saw this abandoned Honda Fit in a carpark that was getting repaved... they just 'cut around it' and continued with the job! There's a number of reasons why the car could have been abandoned, but as for the construction company, legally they don't have permission to move the car from the owner (who has moved on and can't be contacted) so all they can do it just leave it there with enough space around it so it won't get damaged.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
