Hey I was just wanting to find out some info/problems/advice or if any one has done or heard of turbo engine swaps for 1981-1985 HR/DR/MR30 Nissan skylines such as L28et, RB30det, RB20det, RB25det any others because I am curently thinking seirously about puting on into my HR30 4 door Non turbo because I have a bit of coin saved up. Also any photos of your modded R30s would be greatly apreiciated. THANKS.
I have an L28E in mine, was going to turbocharge it but a manifold was about $1500 minimum.
Then i thought of an RB25, but thats going to cost atleast $7K.
Since then its been crashed i am getting it fixed selling it and buying a S132 with RB25DET
theres a few r30s out there with some swaps
best is prolly http://nissanking.cjb.net
thats what i'll be doin to mine, just need to find the appropriate parts for my motor.
from what i've read for the r30
rb25 needs to have the sump modified
rb20 goes in with minimal mods to gearbox mounts
rb30 sits too high requiring either bonnet raised or sump cut n shut
all swaps are over about 6k cause u gotta change heaps of stuff like diff brakes zorst prolly cooler and so forth
thge rb20det is a direct replacement, talk to justeck and they will give you the information.
all they said to me is.
The mounts line up. you have to rewire the wring harnes for the Pas and Cas. use the Rb bell housing and you can use the l20et gearbox.
thats it simple :D stock wiring harnes, just swap and go :)
when i did the rb20 swap it was a little more difficult then that as we found the gear box didnt line up (bolts), replace the brake master cylinder for the r32 one, engine needs lifting and if you have a mate that is a auto sparkie it will say you a lot of cash, 1000 to re-wire to suit new system?
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
