Hey I was just wanting to find out some info/problems/advice or if any one has done or heard of turbo engine swaps for 1981-1985 HR/DR/MR30 Nissan skylines such as L28et, RB30det, RB20det, RB25det any others because I am curently thinking seirously about puting on into my HR30 4 door Non turbo because I have a bit of coin saved up. Also any photos of your modded R30s would be greatly apreiciated. THANKS.
I have an L28E in mine, was going to turbocharge it but a manifold was about $1500 minimum.
Then i thought of an RB25, but thats going to cost atleast $7K.
Since then its been crashed i am getting it fixed selling it and buying a S132 with RB25DET
theres a few r30s out there with some swaps
best is prolly http://nissanking.cjb.net
thats what i'll be doin to mine, just need to find the appropriate parts for my motor.
from what i've read for the r30
rb25 needs to have the sump modified
rb20 goes in with minimal mods to gearbox mounts
rb30 sits too high requiring either bonnet raised or sump cut n shut
all swaps are over about 6k cause u gotta change heaps of stuff like diff brakes zorst prolly cooler and so forth
thge rb20det is a direct replacement, talk to justeck and they will give you the information.
all they said to me is.
The mounts line up. you have to rewire the wring harnes for the Pas and Cas. use the Rb bell housing and you can use the l20et gearbox.
thats it simple :D stock wiring harnes, just swap and go :)
when i did the rb20 swap it was a little more difficult then that as we found the gear box didnt line up (bolts), replace the brake master cylinder for the r32 one, engine needs lifting and if you have a mate that is a auto sparkie it will say you a lot of cash, 1000 to re-wire to suit new system?
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
