Assume the bore needs to be re-bored. The rebuild used 20thou oversized N1 pistons so bore is probably 86.5mm already. The R32 crank when balanced was given the larger oil pump drive collar.
I bought it off a friend when he removed the head after the hiccup and went RB30
https://www.sau.com.au/forums/topic/254256-rb26-bottom-end/#findComment-4391112
