  • Replies 46
i dont know if any workshop speciallises in HICAS
but i would say that most good import workshops like boost worx and graham west workshops
would know what they are doing and should be able to help you out there mate
good luck with it mate
never good to hear cars with problems
Hi Guys...
My GTR has got some interesting HICAS issues and im looking for a workshop that has experience troubleshooting these problems. Can anyone suggest a place? Please only make a suggestion if you know they have experience with HICAS specifically.
Thanks.
Boostworx can get the diag codes out for u for $50 or so - where it leads u from there is another matter... I too have hicas issues and must be alone when I say i really like it and dont want a lock bar
-D
Thanks for the reply, not really looking for a specialist, i doubt there would even be such a person :D (although with the number of skylines with hicas problems may be there should be LOL) ... just someone who knows their way around the hicas.
-D
Im not keen for a lock bar either :D I dont like the idea of a bandaid fix (although i do read that its better for racing??).
Better for racing so the rear end is predictable around all conditions - its better for street driving and people who admittedly aren't highly skilled (such as myself). PM me the details of whats happening with your HICAS and I might be able to point you in the right direction. I've managed to solve 2 minor hicas issues before but this current one I believe is related to a faulty steering angle sensor (or boss kit) but I won't know for sure till I get the diag codes out (and I just havent got the time at the moment to head to boostworx)
-D
A lock bar isn't a bandaid fix it simply replaced a badly engineered bit of Nissan bandaid fix.
Do you have the GT-R workshop manual? There is an exhaustive section on diagnosing HICAS issues. Start by reading the error light on the HICAS computer.....
Hicas lock bar will fail Regency... and then you'll need to install it back on and have it engineered.
Boostworx will pull the codes off it, but they get someone in a little van to come around to do it, as Shaun doesn't have the equipment on site.
There's no real Hicas-savvy workshop, but there'd be plenty of mobile auto electricians with the diagnostic tool that simply plugs in to pull the codes off...
If it's going crazy, jack up the car, make sure all 4 wheels are off the ground, turn on the car, and the hicas computer will reset itself. It's designed to do this when it senses that no wheels are touching the ground.
I am pretty sure that graham west workshops have that little diagnostics tool
plug it in and it will search and find out your codes
If you search this site you may find a procedure for getting the codes, I know you can for the R33, not sure if the 32 is different.
could you please PM me how to mate.
Its a good thing to know for future
thanks
Edited by Krishy
Ive got the manual and the procedures from it... i just cant get through the crazy setup instructions to put it into diag mode... and even if i had the codes, i dont have the skills/knowledge to replace what would need replacing/fixing :) <-- mechano tard. :P
I'm trying to track down anyone that can do proper HICAS diagnostics (ie: the real-time stuff with steering angles, etc that Nissan can do with CONSULT) too. I've been in some discussions with the people from DTA Motorsport (Who write the ConZult software) over whether their software can do it, but initial checks seem to indicate that it won't work on my R34.
It won't work on an R34 because they used a different type of ODB connector.
Conzult (the full package) will read HICAS diags on 32 and 33's cause it has the same connector. You do however need a stock nissan ECU to 'translate' the codes from the hicas ecu. I did order one but the vendor in australia is that bad at communication it might just be worth me buying it from overseas. And I haven't found a place that does the diags yet. I called Graham West this arvo but haven't heard back from them yet as they were busy and their receptionist took a message...
Its not a huge priority atm but I >will< buy the conzult package after I get my idle issues sorted... I very much want my hicas to work.
-D
Edited by Dohmar
I had my standard rear steering rack locked up with washers and had the parts for the hicas removed from my power steering pump, so it all looks standard and passed regency, but its fully locked :)
any info on this here?
-D
Are you talking about the consult device reffered to in the workshop manual? That piece of equipment looks very very useful... how much does one cost by the way?
    • Ah yeah I forget we aren't talking about an RB.
    • Fellow ADHDer to fellow ADHDer; Don't chase that paint perfection. Paint the bumpers, and put them on.  Leave the respray for another day. Plus, no one is going to see those old areas above. Any spots of surface rust, give them a clean up, prime, then hit with a white paint just to protect them from rusting. Again, no one can see it.   #Mine hasn't been on the road since 2011 cause ADHD... I've slowly learned not to keep f**king with shit if I don't need to...
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
