Engine Reconditioners Se Suburbs...
After almost 200,000kms I'm now down two cylinders and am looking for either a re-co engine or to have mine re-co'ed (preferred option!).
Can anyone recommend a decent engine reconditioner in the SE suburbs... preferably who doesn't charge the earth! I'm not looking to get a 'race' engine built... i.e. no forgies or anything like that... basically just return the engine to a similar state to it came out of the factory.
If I get a chance later on in the week I'll go through the yellow pages and make a fair few calls, but just wondering if there is anyone you guys have used that you'd recommend!
Cheers
https://www.sau.com.au/forums/topic/254278-engine-reconditioners-se-suburbs/
after rebuilding an evo engine and paying about 6k to get it done, only to have it last another 2 years (and not a very good 2 years)
when that motor went for the 2nd time i went the option of getting a low ks engine from an importers, plugged it in and off i went
best $2400 i ever spent
there nothing like a low k's factory engine
rebuilding an engine would be my last option
unless you replace EVERY moving part of the engine, not just pistons rings bearing ect, its still going to be worn in most parts as much as it is now
plus resell ya old engine for a few hundred and it just gets cheaper :P
after rebuilding an evo engine and paying about 6k to get it done...
6k.... well that's a fair whack more than I was expecting.... :)
I was hoping more around the 3k mark :P
Excuse my ignorance, but I was under the impression that a full rebuild basically left you with an 'as new' engine... i.e. all new bearings, pistons, rings, valves, etc... am I misunderstanding?
Edited by Samon
depending how far the rebuild goes, but i doubt most places replace things like oil pumps valve guides cam bearings
then ya got things like power steering pumps and such, if they are your gonna be paying far more than and average rebuild
plus you got labor and machining costs, your gonna get charged for engine removal/refit anyway
not saying you must get a replacement motor but just something i wont do again
Proper engine rebuilds are costly. I recommend sourcing a long rb20/rb25 motor from a wrecker with warranty. Shouldnt cost you more than $1200 for the engine or $2000 all up drive in /out and you can sell off the rest of your engine for about $250-500
Yeah, that's what I think I'll do. I've had a few different quotes for rebuilds... the best was about $2500, but then I've either gotta find the time to remove/refit or pay them another $500-$800... I have a line on an engine with about 60,000kms on it for $1500 but I'm still looking around. No real rush as I've got the Lancer, but I'm really itching to get back in the 'line!
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
