hay guys im trying to run a digital shift light n a oil pressure warning light with a oil pressure gauge n a water tem gauge, both mechanical lines n Auto meter.
i wana mount them on my dash but i don no were to run the braided lines,
i was thinking bout seeing if i could run them through the windscreen vents. is it possible n were is the best place to run them through the fire wall to get it to the engine?
can anyone help me as these are critical before i get this car down the strip to see wat time i can pull.....
I would never run an oil pressure line into the car. From your wording it sounds like a mechanical gauge which is not only illegal to have inside a car, it's highly unsafe as the risk of a line or hose end coming loose, causing oil to spill and potentially start a fire or cause blindness. My suggestion would be to change over to electrical gauges with warning lights built in. Might be more expensive in the short term but worth it for the longevity of both you and your engine.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
