hay guys im trying to run a digital shift light n a oil pressure warning light with a oil pressure gauge n a water tem gauge, both mechanical lines n Auto meter.
i wana mount them on my dash but i don no were to run the braided lines,
i was thinking bout seeing if i could run them through the windscreen vents. is it possible n were is the best place to run them through the fire wall to get it to the engine?
can anyone help me as these are critical before i get this car down the strip to see wat time i can pull.....
I would never run an oil pressure line into the car. From your wording it sounds like a mechanical gauge which is not only illegal to have inside a car, it's highly unsafe as the risk of a line or hose end coming loose, causing oil to spill and potentially start a fire or cause blindness. My suggestion would be to change over to electrical gauges with warning lights built in. Might be more expensive in the short term but worth it for the longevity of both you and your engine.
