  • Replies 86
I did see a few Holdens and Fords sitting in middle lanes with hazards on...
Don't people know to push their cars off the road anymore...
In fact... ...that should be a requirement to buying a car... ...Can you get out and push it???... ...If you can't... ...It's too big for you to buy...
I've been asked if I can pick up a motor bike before getting on one... ...you drop it and you're all alone... ...and you can't pick it up... ...you're stuffed...
I wonder if the words "Vapour-Lock" still exist.......?
mmmm....well, I guess they do!!
Well, what would I know...heck, I just drive a POS Skyline.......(according to many 'old school' V8 Holden and Ford owners).
I had to Wikipedia "vapour lock"... :)
To all of those paying out on the Fords/Holdens, how many skylines do you see driving around with 400,000kms on the clock without having been rebuilt?
Go line up against a new GT/F6/R8/GTS etc for a few consecutive runs on a 40 degree day, then come back and post up the results
mmmm....fair enough...though I'd like to see "a new GT/F6/R8/GTS etc " with 400,000 kays on the clock....at any temperature, let alone a Skyline.
Tell that to all the soccer mums with their over sized 4WDs
Mine runs fine in the heat. Oil temp is just on 70 sometimes a little over. Not as much power as in the cold but in this heat I can't be arsed driving so it's usually a very mellow 1 hour cruise home.
On the westgate freeway today around 9:50am going into the city just before williamstown rd I saw 9 cars pulled over all changing their tyres!! Dunno what was on the road but what ever it was they all copped it!!
I used to own a 94 EF falcon on my P's in 98-2001 and that thing was awful in the heat! I had to drive it with the heater on all the time to keep the water temps down! Then I blew a heater core and the footwell carpets got soaked. On a hot day I'd come back to the car and all the windows would be steamed up then insidde it was like a wet sauna!! YUCK!!!!
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
