  • Replies 86
Bloody oath boyz, my cars been in the garage for the last few days and im sure over the next few days too since its 40+
installing factory airbox back and possibly a water/methanol spray to keep intake temps down + a higher grade oil *w50 etc
drove back from geelong a little while ago when it was 35ish and oil temps went to 90 but didnt move much from there, water temps were 86-88
They really dont like the heat, especially with a front mount.
ohhh a little device which has helped is my billion variable fan controller which turns on the aircon fan at a preset temp + can run 1 extra auxillary fan which i may look into asap
Different story for me today from the other day. Driving into work this morning I had aircon on 20 and got stuck in traffic on the wesgate. Was all the way back to the ring road. I was worried for a bit as the oil temp almost got to the 110 mark, water temp didn't move though (I will take lappy in car tomorrow and run NIStune to check actual temps) then I got to the bridge and saw the cop cars everywhere and the 3 news choppers hovering, this was around 10am. Then I got to work and saw that that wanker threw his 5 yr old daughter off the bridge which is why the traffic was bad and I felt bad cos I was cursing about the heat!!
I saw that on the 6pm news... ...Crazy fcuker...
- May she not have felt much pain - May he rot forever more -
yeah I wanted to see it on news as all I got all day is from the net. Still at work now, might get it on the late news tonight.
If I had of seen it I would have chased him down in the GTR and smashed him off the road!! It's just a car and I have insurance but that poor little girl :(
Mine's about the same if I get stuck in traffic for a while with the air-con on in this heat. I couldn't work out what temp it was, then I realised half way between 70'C and 150'C is about 110'C, which is fine. It's not going to hurt anything. If you see your stock water temp gauge move from it's normal position - then worry. They stay in the normal spot between certain heat ranges, if it moves it outside of normal.
thats cool, thanks for that. my water temp never moves from halfway so its fine then. i drive mine without boosting it and just cruise with the aircon on.
i hate the hot weather sooooo much.
edit: +4 this is when you need the death penalty and throw him off the bridge.
nah not for a car with big cams that idles around 1000rpm... really thick FMIC and alloy radiator don't help either, it needs plenty of airflow so putting around in traffic doesn't help
when you see 110º+ water temp its time to worry... what temp does coolant boil at, anyone know?
now an Evo tuned to run 98 running 91 on a 40º day, that sounds unhealthy lol
depends on the coolant/water mix, says on the bottle. i mix mine for 127deg boiling point
Oil 110
Water 90
All within normal :P
Driving with boost and aircon on full.
110 degrees celcius is normal??? I'd be pretty worried when my oil hits 110 it starts to thin out...
Unsafe? :P
Ever been in a taxi?
I used to drive a security patrol car. It was an Echo and the car at that time was on 700k+ on the odo.
Driver side door seems to have more problem than the engine itself because we hop in and out around 150 times a day. :ermm:
That's what mine's sitting at with air-con on in traffic, and it's pretty much stock. It drops about 10'C if driving for a while. Can't expect the poor car to be able to cool much more when the ambient temp outside is 45'C and the air-con is running at full steam.
110'C is fine. It's higher than what you're used to seeing normally but it's certainly not going to cause damage. You just don't thrash it or place it under excessive load at that sort of temp. And keep an eye on your oil level.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
