  • 9 months later...
hi guys,
This works fine. I have tried this 4 times now it works but it light up again while driving( may be after 1day or 15min). what can it be ? resetting is not helping. when i first got the car there was no probleme. it all started after compliance OR detailing.
can anyone help ? P L E A S E :sick:
If the light keeps on coming up then I would suggest you find a mechanic/Nissan who have a Consult machine to plug into your car and determine what the real reason for the error code is. It could be something really simple like a loose wire or it could also mean ur airbag is faulty which you don't want happening.
i took my V35 to the agents & hooked up the diagnostic for codes. all it gives is,
No Current Codes
Past codes are B1166 CRD LH(OPEN)
Erased codes from past history.
& before i could even drive out from the agents the light is back on.
It's something to do with LH side floor wire harness. Do you reckon i should remove the LH side floor harness, clean it & fix it????
Have you got any idea ?this is what i found on the internet
anyone? chris rogers ??
As per page one of the attachment...
Be very, very careful looking or playing around with any SQUIB or associated circuit...
This may fire the Airbag, as SQUIBS are generally small electrical devices that allow an explosive device to discharge. Static electricity from your fingers or tooling can fire these devices and should be treated with extreme caution.
Make sure you disconnect the Airbag itself at the very least.
No Current Codes
seat belt pretensioner is fcukd. its common on cars of that age. the other one that pops up is the main module failing. there was a TSB on that.
there are a few air bag related things on them.
ST,
indeed. they don't like sudden shocks either :) at the VERY least drop the battery - go have a cuppa and then pull it apart.
  • 5 years later...
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
