The Insurance Thread
heslo
 Share
I don't know why people even bother with them? If they can bullshit you with reasons why they can't insure you, what makes you think its going to be even better with a claim?
I know Wayne got f**ked when someone reversed into him. They ruined the side indicators on the quarter panels then when his headlight got moisture in it they blamed it on age, even though the other side was fine nor was it leaking water into it before the accident. So they refused to fix it. Bullshit.
just got my renewal from just car, dropping my value by $3,500. guess ive come to expect this by now tho.
Strange, mine actually went up from $21,050 to $22,500 on JustCars :D
good old insurance, I moved closer to town (the dirty south = ghetto ) and it doubled the monthly cost. had to nego to get it lowered to only 20.00 a month more then aldinga beach
and value has fallen by 600 bucks without warning. but agreed value is still really high, 29,400. (shannons)
end rant. :)
time to move again...lol
someone needs to create an insurance company that does something along the lines of e.g. you only do 5,000kms a year on your car so your insurance only costs xx amount. As oposed to you have to pay a full premium every year.. it's crazy there is only a really small amount of insurance companies to insure people with imports. Surely there's plenty of people who only use their cars as weekenders (if that!) yet we still have to pay the same. They do it for nana cars so why not ours..?
you will find that shannons does insure you on your circumstances....ie if your car is a weekender then your insurance premium isnt that high....but i think that means your not covered from monday - friday....so its a big risk you take....but if you only drive it on sat and sun then shouldnt be a problem.....
yeah we do have it set up like that with shannons.. a weekender and a daily.. we thought it'd reduce it but it really didn't.. the weekender car literally does no more than 5,000 kms a yr.. it should be based on how many kms you drive it as aposed to being a 'weekender' that gets done all day sat/sun .. if that makes sense!
Edited by sare
i cannot remember who the insurance company was that had their Ad on the tv.....in regards to pay as you go or something like that.....i didnt look much into it however but it might pay for you to look a bit into that Sarah :P
they dont cover imports im pretty sure.
plus, this:
Underwriting knockout
We are unable to offer you an online quote for the following underwriting reason(s):
We do not underwrite one or more of the modifications on your car.
One of the drivers of the insured car is under 25 years of age.
We apologise for any inconvenience this may cause you.
If you think you made a mistake on the previous page, please click the "back" button and correct your answers. Please remember your Duty of Disclosure, which is outlined on the top of the first page.
Said modifications include:
* AMG
* Active Suspension - Bounce
* Air Brushed &/or Chameleon Paint
* Blow Off Valve
* Bonnet Scoop(s)
* Drop Fuel Tanks
* External Fluorescent Lighting
* Flamer Kit installed
* Lowered Suspension - Non factory fitted
* Nitrous Oxide System - NOS
* Non Standard Body Kits
* Non Standard Boost Controller
* Non Standard Carburettor
* Non Standard Engine
* Non Standard Intercooler
* Non Standard Supercharger
* Non Standard Turbocharging
* Performance Cam Shaft
* Performance Cylinder Heads/Modifications
* Performance ECU Chip
* Performance Exhaust System
* Racing Harness
* Raised Suspension - more than 50mm
* Roll Cage
* Wheel Arch Flares
* Non Standard Cold Air Intake
http://www.payasyoudrive.com.au/
 Share
    • FWIW, I've always found Toyota A/Cs to be much colder than Nissan ones. Even that 2024 Nissan X-Trail (that VW Australia lent to me), the A/C isn't as cold as other base model Toyota Corollas/Camrys, etc. Maybe Toyota A/C compressors are superior?
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
