I don't know why people even bother with them? If they can bullshit you with reasons why they can't insure you, what makes you think its going to be even better with a claim?
I know Wayne got f**ked when someone reversed into him. They ruined the side indicators on the quarter panels then when his headlight got moisture in it they blamed it on age, even though the other side was fine nor was it leaking water into it before the accident. So they refused to fix it. Bullshit.
good old insurance, I moved closer to town (the dirty south = ghetto ) and it doubled the monthly cost. had to nego to get it lowered to only 20.00 a month more then aldinga beach
and value has fallen by 600 bucks without warning. but agreed value is still really high, 29,400. (shannons)
end rant. :)
time to move again...lol
someone needs to create an insurance company that does something along the lines of e.g. you only do 5,000kms a year on your car so your insurance only costs xx amount. As oposed to you have to pay a full premium every year.. it's crazy there is only a really small amount of insurance companies to insure people with imports. Surely there's plenty of people who only use their cars as weekenders (if that!) yet we still have to pay the same. They do it for nana cars so why not ours..?
you will find that shannons does insure you on your circumstances....ie if your car is a weekender then your insurance premium isnt that high....but i think that means your not covered from monday - friday....so its a big risk you take....but if you only drive it on sat and sun then shouldnt be a problem.....
yeah we do have it set up like that with shannons.. a weekender and a daily.. we thought it'd reduce it but it really didn't.. the weekender car literally does no more than 5,000 kms a yr.. it should be based on how many kms you drive it as aposed to being a 'weekender' that gets done all day sat/sun .. if that makes sense!
Edited by sare
i cannot remember who the insurance company was that had their Ad on the tv.....in regards to pay as you go or something like that.....i didnt look much into it however but it might pay for you to look a bit into that Sarah :P
they dont cover imports im pretty sure.
plus, this:
Underwriting knockout
We are unable to offer you an online quote for the following underwriting reason(s):
We do not underwrite one or more of the modifications on your car.
One of the drivers of the insured car is under 25 years of age.
We apologise for any inconvenience this may cause you.
If you think you made a mistake on the previous page, please click the "back" button and correct your answers. Please remember your Duty of Disclosure, which is outlined on the top of the first page.
Said modifications include:
* AMG
* Active Suspension - Bounce
* Air Brushed &/or Chameleon Paint
* Blow Off Valve
* Bonnet Scoop(s)
* Drop Fuel Tanks
* External Fluorescent Lighting
* Flamer Kit installed
* Lowered Suspension - Non factory fitted
* Nitrous Oxide System - NOS
* Non Standard Body Kits
* Non Standard Boost Controller
* Non Standard Carburettor
* Non Standard Engine
* Non Standard Intercooler
* Non Standard Supercharger
* Non Standard Turbocharging
* Performance Cam Shaft
* Performance Cylinder Heads/Modifications
* Performance ECU Chip
* Performance Exhaust System
* Racing Harness
* Raised Suspension - more than 50mm
* Roll Cage
* Wheel Arch Flares
* Non Standard Cold Air Intake
http://www.payasyoudrive.com.au/
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
