hey guys was just wanting to know some stuff before heading over the pits
Well my cars pritty factory except for a few things witch i need help with
Car is running a Rb30det but it has a top mount turbo setup instead of a standard setup i was just wondering if this is legal or not its pritty close to the bonnet, also has adjustibles and foward faceing plenum will any of this effect my car passing
Would appretiate any Info guys
Cheers
https://www.sau.com.au/forums/topic/254347-some-questions-about-the-pits/
really comes down to the inspector you get
some say you need a engineering cert some arent fazed
ive passed with a high mounted Supra before but i had engineering cert
and the inspector really just have it a quick once over
Bubba's also had success passing with his rb30 in his r32 (but that as on a standard setup)
best thing is just pay the $83 and see what they want you to change
I believe ossie had to get his car engineered.
TBH, the highmount will cause dramas. I have done mine in phases, Phase.1 was get the RB30 in, running and licensed - I think the fact that it looked stock under the bonnet and the fact that power delivery wasn't huge turboish, helped. Phase.2 is highmount turbo and I'll cross the licensing bridge when I get to it.
Edited by bubba
O true well the motor is already in and running looks stock as a rock besides the foward faceing plenum and high mount,, its a bit hard to hook up a standad setup without water lines any more lol, ived used all the rb20 cam and rocker covers so sould be sweet,, if not i will just have to buy a Standard Rb20det just to get over the pits
the car was licenced but i let the rego laps, not to worried about getting the 30 complied as cant tell from the naked eye, unless you know your skylines real well so police shouldind be botherd, i just want to make it over the pits so i can get new rego
that didnt go down with me, he told me i got a leathal weapon cause of the twin turbos. my 26 is all standard but its just all painted so first impression is looks like there is soo much work done to it.
thanks guys i think im just gonna run it over the pits as is and see what the kick a shit about ive changed my Engine numbers the dpi gave me a form cost like 50bucks hopefully should be all good dose any one know were to get an engineering cert from?
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
