Surprised there hasnt been an ongoing sticky topic for this, but what fuel do you all use? how would you rate it? what kms do you get? any brands better/worse than others?
i myself use Shell V-Power (98RON) get generally 350kms around town per tank and 500-550 out on the open road. Series 1 RB25DE with no mods bar intake.
might be good to help out newbies in the skyline scene and prevent confusion about what fuel is recommended for RBs.
https://www.sau.com.au/forums/topic/254366-what-fuel-do-you-drink/
  • Replies 48
well theres really only two choices isnt there?
v power or bp ultimate.
i wouldnt let anything else near my car when it can be avoided.
that said, i was outraged to pay $137.9 for ultimate today. in a metro area. what a joke. crude is $45 a barrel for fox sake!
The only way to go is BP Ultimate and E85 on a 10 to 1 mix.
My GTR was tuned for Shell V Power Racing 100 RON and by changing to this mix on the same tune I picked up 10 kw and the car runs cooler. E85 is a good cheap octane booster that really works.
how much per litre? its still 128.5 down here for premium
i personally dont touch shell v power at all.... I find that i get less km's out of it and less power....
Usually use mobil 8000 most of the time, then bp ultimate if mobil is out.... used to use vortex 98 religiously, found no difference in performance, operating temps or milage compared to ultimate or 8000, only difference is around my area its usually more expensive than the rest....
I have used united 98 octane fuel and i find it pretty good, no problems with my car.
shell in my area is by far the cheapest but i get high end pinging when i use it, also had idle issues with it... my car probably isnt tuned right for shell fuel, each car is different so just find whats best for your car. There is no one right answer to this question.
I was using United's boost98 for a long time but have recently changed to BP Ultimate. Roughly about 400km's stop start and short trips, but did Adelaide to Hardwicke Bay on just over 1/4 of a tank! Have been told to stay away from the local Shell, dirty tanks!
Caltex produces all the petrol for shell and bp , mobil produce their own 98 from Melbourne
i find them all pretty much the same,,,,, still i cant stand shell, different colour = not exactly the same, there is still a difference between shell and the rest acording to how my car behaves, even though its derived from the same source....
It's all the same bp has an actual ron rating of 98.6 that's why your car behaves better... And bp also charges the most 14c per litre more than standard fuel compared to 10c a litre more at other joints!
Mass protest!!! And also the guys at bp all have bad customer service!
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
