Just wondering why my car (rb20det) makes no boost if i rev it in neutral ?
just thinking about it, with the clutch pedal depressed, sitting still, its really the same as if i was driving with the clutch engaged at speed.
The engine is still revving to a certain RPM, therefore consuming a certain amount of air (correct me if im wrong).
so shouldn't the turbo be spooling ?
https://www.sau.com.au/forums/topic/254434-silly-question-probably-but/
There is no load that's why you won't see boost in neutral when just pushing the throttle.
However.... if you modulate the throttle you can achieve positive boost in neutral. Play with it let it rev down and hit the throttle a bit, you'll see a + reading. It's not sustainable but possible :)
turbos only respond to load (exhaust energy). no load no boost . to over simplify it . less air = less fuel = less exhaust energy.
if you floor it and let off before redline (or not if your so inclined) you should see the positive side of the boost gauge but f all
Does it have a stock ecu?? The R32 GTS-T (or mine anyway) with a stock ecu will NOT build any boost in neutral. I didnt even think about this until i had my troublesome after market ecu pulled out. It would spool up in neutral with that in, but as soon as it was out i thought i had a blown turbo lol. Just a factory safety measure....
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
