In my S1 R33, the fuel gauge is currently reading full until I hit around 180km (less or more dependant on driving, more for highway, less for when I'm in a bad mood), and I don't really know how it works so that I can fix it. From what I've seen, the sender for it is a long kind of bar that goes in the tank, and as I'm replacing my fuel pump with a Bosch 040 next weekend, thought I might do this too.
The picture attached is how I kind of figure it works, the left is normal and the right is what I think may have happened, it's come loose at the top and is laying down against the side, so when the tank is full, the float is stuck at the top until the tank level gets down to there.
This happened after a skidpan day at Oran Park in May 2007 so almost 2 years ago now, I think it's finally time to fix it. :)
Anyone with any ideas, this would be greatly appreciated.
https://www.sau.com.au/forums/topic/254439-fuel-gauge-busted/
This is what they look like (in s13 anyway):
That little float pivots an arm that is rubbing against a series of different points on a circuit board. When it is low, it rubs on the lower points, giving a lower reading. When its high, vice versa.
Check the tracks on the board and make sure its making contact through the whole range. You should be able to test this with it out of the car just plug the fuel pump loom back in and have a play.
  • 5 months later...
I have some pics of the last time I fixed mine, I'll post them tonight.
The floater and the pump are seperate, but they are on the same bracket, side by side.
Actually.... look here for pics.
http://www.skylinesaustralia.com/forums/R3...=fuel&st=20
When you look into the fuel tank with the top of the tank off you wil see a long white/brownish round tube in the right connor.
This is the fuel sender unit and i bet it will be laying/floating around. it should be clipped into the front of the tank beside the fuel pump bracket.
You should be able to clip it back in no problems.
Mine has the same problem after the last DECA day with a full tank of fuel.
Hopefully i will have time to fix it tomorrow and find a way for it to stay there better and get some photos at the same time to post up.
Cheers
NutR33
Cheers
NutR33
Thanks for the reply, I appreciate it :D
Now that I've got my boot completely empty in preparation for my new boot install, I'll take a look this weekend. Would be nice to know how far a quarter of a tank gets me (not very far I guess). While I'm at it, might as well install my Bosch 040.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
