Um, I'm essentially looking for some coilovers and for them to be installed and set up correctly. Unusually, I've hit a brick wall with my preferred GTR fettler.........They reckon the stuff I need is 'very hard to get hold of' and it might just be a little too hard......Frustrating.
So, I'm asking for a recommendation of a suspension specialist or GTR workshop that will do this for me. Also, anyone who knows their shit about how to set up an R32 GTR, any advice or help you can offer would be gratefully received.
I've got the following already
Adjustable swaybars
Adj castor and front camber
Most bushes replaced
Cheers.
https://www.sau.com.au/forums/topic/254448-r32-gtr-suspension/
  • Replies 119
Posted Images
Step 1: Go to importmonster.com.au
Step 2: Sign up for an account
Step 3: Buy these...
http://www.importmonster.com.au/view?url=h...&title=TEIN RS BNR32 RB26DETT TEIN CIRCUIT MAST
Step 4: Take to racepace and get them revalved and some new springs.
Job Done.
Thanks Andrew. Somehow I knew I'd end up with Racepace....... :(
My car will be driven on the road, so I can't have a full on track set up. I need some compliance too. Does the set up you've described suit that?
http://www.tein.co.jp/e/products/super_racing.html
This them?
Thanks for your input.
You could also talk to Quadrant Suspension in Berwick. I believe they set up the Bilsteins that the Nissan Race team used. (I'm running them in my 32 GTS4, and they are quite good - firm but not kidney-rattlers).
Or even Toperformance in Vermont South - for Konis.
Nick, if you decide to go the Teins RE/RA/RS and Racepace route then give me a call :(
Jack and Snowmans cars run this setup and are very compliant on the street. I run the RA and they are a bit firmer in my GTSt but i think the ride is still very good.
Give us your number then!! Kinda lost it. Cheers.
Thanks Arch. Chris at Centreline really helpful. So was everyone else mind you.
Anyone got a view on how appropriate these are over the Circuit Master RS as recommended by BBGTR? They will be re-sprung and possible re-valved in any case.
What do Tein Super Streets sell for these days? The slightly softer Aus spec and the Jap Spec?
They worked well enough that Mark and Russ won Dutton Rallys with them and other similar events and were quick enough to be one of the quickest Skylines around Wakefield
http://au.youtube.com/watch?v=dHm-uvIt8wg&...re=channel_page
What are those? look very similar to the RS's...
The RS shocks have the reservoirs mounted to the shock body with a cast alloy carrier where as the Super Racing are on braided line that allow you to mount them remotely like in the engine bay on the strut braces or in the boot etc. Makes adjustments on the fly a little easier
No need to go over the top for a mainly street car and waste massive amounts of money on something you will never use to its full potential and you need somebody else to set it up for you because there a thousands of combinations you can use. Some V8 drivers use shocks like Benno at racepace to fine tune their cars whereas other V8 drivers setup their cars using swaybars. Its personally choice. Setting up off swaybars and ride height is a hell of a lot cheaper.
A set of correctly valved bilstiens are cheap and should do the job. Its all I have in my car with 7kg/mm in the front and 5kg/mm in the rear. Don't need to be a scientist to work out those rates as everybody pretty much runs around that rate. I don't have super power and am hoping to run so good times for 280utag or whatever it is grip rated tyres. I'm finance limited to the amount of track time I can get. I also have my front toe and rear camber set by myself with no measuring equiptment as the tyre place didn't get it quite correct so I guessed it. At DECA I can sometimes beat and most of the time go within 1 second of Snowman and Scotsman on Motocarna type events if I don't make mistakes but they kick my ass on the circuit due to there power/tyres and brakes. Just goes to show big $ susp isn't the main thing. Experience and feel for your car are the best things to make yourself go faster so the $2000 or more you save on lower spec susp you can spend on 5 more track days that will make you a better driver and know how to control a car. Just my 2 cents. Big $ bling bits are cool but I bet 95% of the people who have it don't know how to set it up themslves which is what I believe is part of motorsport. Knowing how to make a car go faster yourself and understand why, not just cheque book racing and taking your car to a workshop every time something doesn't feel right or you don't get the time you want. Once your car is setup and you learn to drive around it the way it is you will rarely ever need to touch the susp for different tracks. Call me and I can give you a few pointers. I am by no means a super driver but have set my car up on a budget and belive it is pretty good for the $ spent and never been to a workshop apart from the first wheel alignment which was just a local tyre dealer set to my specs.
Haven't had the car on the road for a year now as I have been over it a little and there is more fun to be had for less $ like bikes and boats. Just need to put it back together now as I stole some bits for my other gtr. I can take him for a ride but there is no where near my house to give it a bit or any good corners to throw it around. The track or DECA is the best place to show how it goes.
  • 1 month later...
Well I went down and had a long chat with Jim at Quadrant today. Seemed like a good guy. Essentially they are offering a drop off and pick up service with Bilstein Monotube B6/8. They are a gas/oil unit and come with H&R springs, fully height adjustable. Small and large springs per corner, custom valving and they thrown in 2-3 re-visits if things aren't up to your expectations and they need adjusting. They align everything once done and set the car up (adjust swaybars etc). Seemed a pretty convincing offering.
I know this flies in the face of the Tein advice on this thread, but surely there are other credible options other than Tein? The Tein route means hanging out on Yahoo Japan looking for some second hand units which seem hard to come by (I've been slow off the mark on a couple of occasions due to being crap) . You're then got to get them here (waiting waiting), re-spring & valve them, take the risk on their condition, get them fitted by someone who made no money on the parts (i.e. extra labour charges). Then you have to set the car up. Not to mention if something goes wrong you have little if any comeback. Lot of frigging around too.....
I know I'm making a case to go this way (for once I will not be taking my car to the other end of Melbourne), but I was impressed with what was on offer in terms of the quality of advice, the product and the service. I'm not going to mention price for modesty's sake, but from my limited experience it seems in spec with what you get for what $$.
Any final thoughts before I put this to bed and hand over my hard earned for the non-recommended Bilsteins.....?
Cheers.
For my 10 cents worth - I have Bilsteins & Eibach springs on an R32 GT-R. The car handles fine & is quick for what it is. If I get sick of the spring rates I can easilly replace them & as you say get the Bilsteins revalved. I have never felt the need to adjust the damper rates or change the ride height for the road. Essentially what most people do is set it up for the circuit & live with it on the road. Reason being to do it properly you need to do a wheel alignment every time you change the ride height/camber or indeed just about anything other than the damper setting.
There are, however, a number of other items that are just as influential to the cars handling - namely upper front link (for camber & to remove binding if you decide to run castor rods with rose joints), LCA's, sway bars, neg camber on the front end, attessa system, HICAS etc etc. These are, as I said, just as important & it would be well worth your while to include them in your consideration.
Bottom line: Bilsteins are good. If the price is good & service is good then you can feel comfortable buying them.
Oh and don't get talked into running stupid (high) spring rates.
Depemds on what Quadrant wanted for the Bilsteins. If it works out significantly more then the Tein Super Streets then i suggest you just grab the Teins. I have turnbed into a bit of a fanboy for the SS now that i have driven a few cars with them. They qre very nice and i strongly recommend you drive a car with them first. Wouldnt hurt to ask Quadrant to give you the number of a customer to see if you can sample the finished product
So if I am reading the literature correctly (:pirate::P ?) the Tein range works out something like:
Super street Front 5kg/mm, rear 4kg/mm
Mono Flex 7/7
Type flex 8/6 - (Type HT?)
Ultimate Spec Circuit Master Super Racing 12/12
Ofcourse I could be hopelessly wrong as these blokes appear to have more product designations than I have had hot dinners....
http://www.tein.co.jp/e/products/index.html
http://www.greenline.jp/catalogue/bccatpar...gory=suspension
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
